Go to Post Don't put any weight into the OPR. It's ugly and its momma dresses it funny. - wilsonmw04 [more]
Unread 18-01-2016, 14:52
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
Re: 2363 Triple Helix week one prototypes
Originally Posted by JesseK View Post
We're thinking about drown-down pads (or similar) to assist in stability and angle adjustment for high goal shots. Strategic placement could also mean they assist with getting stuck in the moat. Our prototyping drive base didn't get stuck unless it skewed far left/right, but that base was also 3" too long w.r.t. the current actual CAD design.
For those of us playing at home, what are "drown-down pads?" I have a guess as to what you mean, but I'm not really sure.
Being correct doesn't mean you don't have to explain yourself.
Unread 18-01-2016, 14:53
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Whoops... drop-down pads. I was multi-tasking, sorry
GitHub
Unread 19-01-2016, 11:06
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Rookie Year: 2011
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Originally Posted by bEdhEd View Post
Have you tested that drive base on the moat?
We tested it right at the end of last night's meeting, with no added weight on the robot. I didn't take video, as I don't consider tests with just the drivetrain weight to be conclusive. That said, driving slowly we did get stuck, though not badly, and the driver was able to free the robot. With a little practice, and the right technique, the robot could traverse the moat every time. We'll see if these results are repeatable with full robot weight.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 17-01-2016, 13:14
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
Originally Posted by asid61 View Post
How much compression did you stick on the shooter?
About 10%
Originally Posted by sanddrag View Post
what amount of center drop you have on the drivetrain
.125"
what diameter the Colson shooter wheel is
2.5"
VexPro p/n 217-4046
how much you are gearing up the CIM?
1:1.21
AndyMark SpinBox
Unread 17-01-2016, 14:17
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
I had the pleasure of visiting the Triple Helix shop over the Christmas holidays, it's amazing the testng they get done in a very small space.
Good job team!
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 18-01-2016, 18:13
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
Originally Posted by Nate Laverdure View Post
numbers
[/url]
Cool. If you guys are gonna roll with chain in tube like I think you did in '15, it would be very... interesting to attempt it with the 3/16" we tried and liked. Some people are also trying anything up to 3/8". I regret that there is no way we can run our setup AND constantly toy with the drop, so we'll probably pick a number in the range, take advantage of the pressure adjustments and let the drivers feel it out.
Glad we don't have to face y'all in districts so we can iron our eventual litany of gremlins out (: Good luck!
Unread 16-01-2016, 22:10
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Looks great! Mind sharing what wheel base and wheel track you're showing? We've been trying to figure out the best spacing but we haven't seen a traverse as clean as that.
Unread 16-01-2016, 22:15
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
It seems like your top heaviness is probably helping you over the rock wall. Keeps you wheels up longer so the front ones hit the wall at a better angle. I'd be interested how things work with a lower CoM closer to what you'd normally be running.
Also I probably don't have to remind you that shooting a single brand new ball consistently does not make a consistent shooter.
Unread 16-01-2016, 22:38
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
Rookie Year: 2011
Nope. I'm still having PTSD flashbacks from the nightmare of trying to tune our foam basketball shooter in 2012.
Todd F.
Photo gallery
video channel
Triple Helix mobile
