Go to Post I bet a lot of us (mentors and students) got into this line of work first because we wondered how things work, and stayed in it because we thought "I can make that work better". Thus starts a life-long battle between perfection and time. So far, time is ahead. - petek [more]
Unread 16-01-2016, 23:53
viggy96 viggy96 is offline
FRC #3331
Rookie Year: 2010
viggy96 is infamous around these partsviggy96 is infamous around these partsviggy96 is infamous around these parts
Best motor for direct drive shooter wheels
We were going to use CIM motors for the shooter wheels, but we were concerned about the weight. Are there any other FRC legal motors which would provide the speed at or above that of a CIM, but in a far lighter package?
Unread 16-01-2016, 23:59
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Best motor for direct drive shooter wheels
775Pro. Gear the speed down 2:1. That will give you ~6000 RPM at 8 volts, which will give you headroom for closed-loop speed control.
Unread 17-01-2016, 00:04
FRC #3331
Rookie Year: 2010
Do you mean the 775pro? Also, we want to avoid gearing as much as possible as it would complicate our design.
Unread 17-01-2016, 00:06
Knufire Knufire is offline
Rose-Hulman Institute of Technology
Rookie Year: 2010
Knufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond reputeKnufire has a reputation beyond repute
I think he does. Remember that it's dependent on wheel diameter too, you want a higher angular velocity on a smaller wheel.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 17-01-2016, 00:16
FRC #3331
Rookie Year: 2010
Hmmm. We were thinking of a miniCIM as well, would that be a good choice?
Unread 17-01-2016, 00:18
Ether's Avatar
Rookie Year: 1969
It depends on how you intend to use it.
At what operating speed are you intending to run the motor?
Unread 17-01-2016, 00:30
FRC #3331
Rookie Year: 2010
At its full RPM, without gearing.
Unread 17-01-2016, 00:39
Ether's Avatar
Rookie Year: 1969
So your team made a conscious decision not to control the shooter wheel speed?
http://www.chiefdelphi.com/forums/sh...88#post1521188
Unread 17-01-2016, 01:06
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
Team Role: Leadership
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Speaking from experience, that is a very effective way to ensure you never make the same shot twice.
One important variable to consider is that battery voltage will change throughout the match (not to mention between different matches and batteries), thus changing the motor RPM, and consequently, where the ball goes when you shoot it.
Unless you're shooting at such a close range it doesn't matter, or such a high speed that the ball is basically ballistic (something I would think would be frowned upon by the refs, not to mention difficult to achieve without any gearing), you need to have a bit of margin in your RPM and a closed loop program to compensate for battery voltage changes.
There are a ton of sensing options available, and plenty of stock code to make them work.
