Re: Aiming with Vision
Check out the 2012 vision whitepaper and roborealm tutorial. That's pretty much where I got my algorithm from.
Did you guys know about the example which comes with the FRC code? It's located in "C:\Program Files x86\National Instruments\LabView 2015\Examples\FRC\roboRIO\FRC\Vision\2016 Vision Example" There's even sample images.
Is that somewhere under the vision folder in the FRC examples you find iin LabView because I looked through there and other folders in those examples and couldn't find this specific tutorial.
Can you send me a screen shot of your Vision Assistant script that was used for your vision code? we have tried several scripts (that are similar to the white paper and that have worked in previous years, but not this year) that work great to finding a target in Vision Assistant, but when they are exported as a VI and used in labview, they dont return any matches. Any chance you could send pictures of your script? Thanks |
Similarly, I'd be interested in seeing/hearing about your scripts that you expected to work, but found that they didn't.
Did you have luck with the example code or aspects of it? Greg McKaskle |
