Go to Post Meh, wear safety glasses. - Mike Schreiber [more]
Unread 17-01-2016, 14:50
CoffeeFlux's Avatar
CoffeeFlux CoffeeFlux is offline
AKA: Ryan Lucia
FRC #0422 (Mech Tech Dragons)
Rookie Year: 2010
CoffeeFlux is an unknown quantity at this point
OM5P-AN Flashing Timeout
Every time I try to flash the new radio (using FIRST's utility), I get the error message "Bridge firmware load failed: Timeout flashing radio." It's able to detect when I power-cycle the radio, and begins to flash, but then just times out and never finishes. Firewall is disabled and the program is run as administrator. Anyone have any ideas?
Unread 18-01-2016, 10:53
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Re: OM5P-AN Flashing Timeout
The KOP radio should already have the right firmware.
Have you tried these instructions for flashing the firmware?
http://files.andymark.com/OM5P-AN_QuickAP_Setup.pdf
Unread 18-01-2016, 10:54
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Are you sure that's the same firmware as the FIRST firmware?
Unread 18-01-2016, 10:58
Rookie Year: 2012
No, but Andymark is pretty good about those things. It is a link from the Andymark Webpage for the Radio. We will be flashing the radios this evening. I'll let you know if it works.
http://www.andymark.com/OM5P-AN-p/am-3277.htm
Unread 18-01-2016, 11:14
JerryBudd JerryBudd is offline
JerryBudd is an unknown quantity at this point
The instructions on the AndyMark page are for non-FRC use applications.
For FRC, you'll want to follow the directions here:
Programming for Home Use for FRC
Unread 18-01-2016, 21:45
Rookie Year: 2012
The andymark instructions worked for me. We could not get the frc configutation tool to work.
