Go to Post College was the best twenty years of my life. - Richard Wallace [more]
Unread 17-01-2016, 20:25
DrewMatic's Avatar
DrewMatic DrewMatic is offline
Djibouti
AKA: Drew T
FRC #0240 (T.E.M.P.E.S.T)
Team Role: Leadership
Rookie Year: 2014
DrewMatic is an unknown quantity at this point
Portcullis/Sally port
Hello CD! Does anyone have thoughts about the portcullis or the Sally port? Would being able to go through these defenses be beneficial?
Thanks, Drew
Projects we have completed demonstrate what we know, but future projects decide what we learn.
Unread 17-01-2016, 20:34
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Portcullis/Sally port
It's a bit late to be contemplating this, but I suppose better now than at your first regional.
Those defenses are in two different groups, and this year, breaching the defenses are worth both a semi-substantial amount of points during Playoffs, as well as Ranking Points. Assuming you've already considered or conquered the other defenses, it simply adds to the abilities you bring to an alliance. The defenses, however, are not always there, so it's a constant risk vs reward battle.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 17-01-2016, 20:35
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Sure, it would be helpful! we are planning on working with our alliance partners to cross the Sally Port, and we don't really have a plan yet for the Portcullis (or the Frei...teeter totters).
Unread 18-01-2016, 07:14
HolyHacker335 HolyHacker335 is offline
FRC #4945 (Titanium Wrecks)
Team Role: Coach
Rookie Year: 2015
HolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud ofHolyHacker335 has much to be proud of
Thanks, Drew
LOL. Expect that BOTH will be in every match! So, yes, I think it would be beneficial. And don't forget the Drawbridge.
Unread 18-01-2016, 10:47
DrewMatic's Avatar
Djibouti
AKA: Drew T
Rookie Year: 2014
Thanks for the input. As of now we can get over the defenses where you don't have to lift,open,etc. We plan on getting through the portcullis, Sally port, and drawbridge, but haven't made anything to do those defenses at the moment.
Thanks, Drew
Unread 18-01-2016, 16:02
[HT]3KEZ's Avatar
[HT]3KEZ [HT]3KEZ is offline
FRC #4014 (Top Hat Technicians)
Team Role: Electrical
Rookie Year: 2015
[HT]3KEZ is an unknown quantity at this point
It depends. Can you get through all of the other defenses (including the low bar)?
Unread 18-01-2016, 18:40
MrForbes's Avatar
AKA: Jim
Excellent point. We were kind of ignoring the portcullis/teeter totters because we plan on going over/under all the other defenses. You can get by with not doing one pair.
Unread 18-01-2016, 19:32
roboLovr123 roboLovr123 is offline
Junior Member
roboLovr123 is infamous around these parts
The bottom of the portcullis is 5 inches off of the ground. If your robot can go under the low bar, adding a small ramp to fold down would allow the Portcullis to slide right over, provided ramp continues over the top of the robot. The sally port is much harder, but could be done with one robot going through from the enemy courtyard and holding it open for a second.
Unread 18-01-2016, 21:26
The other Gabe's Avatar
The other Gabe The other Gabe is offline
Too many events, not enough time
AKA: I'm a volunteer now!
no team (2046 Bear Metal Alumn)
Rookie Year: 2012
The other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud ofThe other Gabe has much to be proud of
I personally see benefit in being able to breach every single defense, but especially important will be the ones that are harder to breach, because your opposition will be picking those every chance they can get.
Do the best you can with what you are given
FRC 2046 2012-2015
Field Scout lead 2014-2015
Unread 19-01-2016, 06:20
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
It would be beneficial to breach each and every one of the defenses. The drawbridge and sally port are trivial if you have two rolling robots, so we're not wasting skull work on fancy mechanisms. Five are drive train and geometry
issues; a lot of work went into our drive train design, and more to follow for build. We plan to multi-task our ball pickup to raise the portcullis and lower one plank of the Cheval de Frise.
