NavX MXP Accuracy
Before we buy a NavX MXP, we'd like to know the following:
Is it reasonable for us to expect that using the NavX to determine the robot's position relative to the field will remain reasonably accurate for a two and a half minute FRC round? |
Re: NavX MXP Accuracy
When you say reletive to the field, are you referring to heading, your xy coordinates, or both? If it is just your heading I would think you'd be ok, however if you're trying to us the navX to track your xy coordinates aswell, you will most likely deal with a substantial amount of drift.
Disclaimer: I have never used the navX board, this response is purely based on what I have read others post here on chief. |
We used one positioned on to of your robot relatively centered to run our mechanum wheels in a field oriented drive. Just set up to recalibrate when the match starts we never had any issues with the rotation drifting. In my opinion plenty accurate for a 2-minute match.
If you are referring to orientation (rotation of robot with respect to the field), absolutely yes. Hundreds of teams have used NavX-MXP for this.
EDIT: Never mind, I think I found my answer: "Accelerometer data from the navX-MXP’s onboard MPU-9250 are double-integrated by the navX-MXP firmware to estimate displacement, and are accurate to approximately 1 meter of error during a 15 second period." http://www.pdocs.kauailabs.com/navx-...ked-questions/ So it's a definite no. Last edited by KyloRen42 : 18-01-2016 at 11:31. |
- wheel encoders + navX-MXP - vision processing w/camera w/navX-MXP - a combination of all of the above - using a "follower wheel" that has a wheel speed encoder (for distance traveled) and an angle encoder (for current direction of travel). |
