Go to Post Mentor to Student: "It's OK, if you mess it up you just get to do it again." - EStokely [more]
Unread 17-01-2016, 22:31
btcshields6 btcshields6 is offline
FRC #4206
btcshields6 is an unknown quantity at this point
Aiming a Turret using Vision and an IMU/Gyro
This is sort of similar to dubiousSwain's earlier post, but less technical, and with slightly different mechanics.
My team is considering using a rotating turret-like shooter, which aims (autonomously) using vision targeting (the shooter turns, not the robot). After reading through dubiousSwain's post, I wonder if it would be better to use the camera to identify the target's distance and angular displacement, and use an IMU/Gyro to correct the angle. I don't know how that would work. I also don't know much about PID, which I saw mentioned. Does this seem like a reasonable plan?
Just so you know, we're trying to decide between these two sensors for IMU/Gyro: BNO055 or ADXRS450 (we're also open to the navX if anyone recommends that).
Thanks,
Benjamin
Unread 18-01-2016, 07:42
Re: Aiming a Turret using Vision and an IMU/Gyro
When you are trying to measure an angle change between two elements of your robot, you can generally use a potentiometer or an encoder. Since the robot isn't attached to the field, that is harder and requires a gyro or IMU giving gyro values.
If both robot and turret are in motion, then you have to take both into account.
Greg McKaskle
Unread 19-01-2016, 21:15
FRC #4206
Thanks. Looking into it tomorrow. A few new sensors we ordered showed up today. I'll try and figure out exactly what we're going to use.
