Go to Post Desperation is the mother of accomplishment. - Koko Ed [more]
Unread 18-01-2016, 13:22
Ronso007 Ronso007 is offline
FRC #3339
Ronso007 is an unknown quantity at this point
Getting the new lifecam hd-3000 to work
Hey Guys,
We tried to connect our new USB camera (microsoft Lifecam hd-3000) to one of the USB ports(we tried both of them) of the Roborio and run the Driver Station.
We chose the 'USB SW/HW' Options and neither of them shown anything.
The camera itself works - while trying to run it through the computer we were able to see the camera broadcast...
Any suggestions?..
Unread 18-01-2016, 13:45
Jonathan L. Jonathan L. is offline
FRC #1094
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
Re: Getting the new lifecam hd-3000 to work
Do you have code running on the roboRIO? The default (LabVIEW) robot project has code in it that forwards the camera image to the dashboard.
Unread 19-01-2016, 07:18
FRC #3339
We got it to work
Thanks!
Unread 20-01-2016, 19:05
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
Rookie Year: 2012
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
We have the same issue of no camera feed. We are a Java team. Any suggestions?
Unread 21-01-2016, 16:00
FRC #3339
Well, first of all check if the camera is working at all, without the roborio.
Then, you need to download Code to your robot and run it, you should see a broadcast..
(We use labview, I have no idea how to get it work in java but this ^ works for me)
