Thread Tools |
Rating:
Display Modes |
Spark Motor Controller vs. Victor SP
For our Rookie team, we have two extra Victor SP motor controllers. We want to use them for our intake wheels in the front to retrieve the boulders.
However, we checked out some teams in Ri3D, and they have used Spark Motor controllers for their intake wheel motors. What advantage is their to using the Spark Motor Controllers over the Victor SP's? Can we use the Victor SP's for the intake wheel systems? |
Re: Spark Motor Controller vs. Victor SP
I do not know of any inherent advantage of the Spark over the SP for an intake wheel.
The Spark does have input for automatically handling limit switches that the SP does not. The Spark is also cheaper than the SP, but controllers you already have are cheaper . I think the teams may simply have had Sparks on hand. |
Hey koreamaniac101,
The main differences between the two are: -Victor SP is a smaller footprint. -Victor SP has higher maximum output... http://www.ctr-electronics.com/downl...er-Testing.pdf -Spark has limit switch inputs I see no reason why you can't use the Victor SPs you already have for your intake wheel. |
From a general perspective both controllers will function the same way. They will both spin a motor and you program them the same. The difference is the price and the limit switch inputs. A use case for the limit switches for an intake is if you want to load your shooter or move the ball to a specific location in your robot, you can set your intake to spin until the ball reaches a specific point (where you put a simple limit switch) and then your motors turn off automatically with no code required. Smart mechanisms make controlling your robots easier. Quote:
-The spark is lighter in weight -Doesn't have integrated wires (which if cut to short or fail make you replace the controller) -Has more visual feedback (through extra LED signal colors_ -Costs $15 less per controller Also yes, the SPARK has a 3% less max power output(according to the specific test setup you documented), but that is a difference that most teams will never be able to perceive or translate into robot performance, especially on an intake roller using gearboxes that range in the 65%-85% efficiency range. Overall, I stand behind the SPARK as a great controller and would love to see them on every robot in FIRST, I also support teams making the right decisions for your situation. We built the SPARK to be affordable and fully featured, so teams could save money while building their bots and spend the extra on other things that they need or just build cheaper robots. If you already have controllers that do what you need them to please use those; if you want the extra features of the SPARK or you need additional controllers for more robot features we would be delighted to see them on your robot. ![]() |
For the Team Cockamamie Robot in 3 Days build, we used both Sparks (which were donated by REV) and a couple Victor SPs (which were
I'd use either, no hesitation. Just make sure you use the same one for both sides if you have more than one motor in play on a mechanism. Rookie-year us saw a team member wire all of one side of the drive with Victor 884s and the other with Victor 888s. The 888s had a far more linear response, so they wondered why the robot would pull to one direction. Sure enough, when everything went to 888s the issue went away! |
Linear response (steady state RPM vs. PWM demand) is important in many robot mechanism controls. Tom Line (1718) presented some results on this, and Ether has used my Whirlpool motor lab to make the linearity comparison of several controllers when they are driving a CIM motor with dynamometer load. We are still working to extend that comparison to the latest controller types. While those results are not complete now, I can say that the SPARK and Victor SP controllers showed very similar linearity. Our early results also confirm CTRE's results (again using CIM motor with dynamometer loading) regarding forward voltage drop across the controllers vs. load current. As others have said, I think most teams will (and should) use controllers they have on hand, or choose new ones based on cost and features. I like SPARKs for their price, flashy lights, and screw terminals -- the latter allow me to select the lead length I want now without worrying that I might need longer leads later on. Last edited by Richard Wallace : 19-01-2016 at 08:30. Reason: links |
I mentioned this on the Team Cockamamie Periscope, but when we opened the Spark boxes we were greeted with what might be holy grail of FIRST parts: two additional terminal screws, in a little baggy, tucked in the corner of the box. As a mentor whose teams have all had at least one Victor sitting in the box with no terminal screws, that right there was enough to sell me! ![]() (Granted, these Sparks didn't come straight from Amazon--they came in a box from Greg. However, it was inside the retail packaging and if this was Greg trying to hook us up I can't imagine he wouldn't just toss the extra screws in the outer box.) |
We're have about 40 Victor SP's in our inventory.
We just finished our bellypan layout for 2016 and couldn't have pulled off what we did without the tight form factor of the Victor SP. If space is a constraint (which it often is), I'd recommend the Victor SP. -Mike |
#10
We are moving to the Talon SRX this year (ordered 20+ of them), but both the Victor and Talon are awesome WRT size. It allowed us to package a lot of electronics in an extremely small size last year (it will help this year too, but we aren't there yet). The integrated wires, when close to the PDB, do save you time and effort when installing things as well. We will likely be terminating the other end with a deans or XT60 connector to make swapping motors easier than before. When we measured, the weight differences were negligible as well when accounting for wire, etc. I think the price point on the spark controller is awesome and will help a lot of teams, but to us there is a benefit that the added cost gets us when talking about size and proven performance. We will check back again next year when the spark has seen a full (arguably one of the roughest) FRC seasons of use, and will objectively make a decision on what to use. For the OP, use what you have, It will work fine. Also, make sure you are using your CTRE/IFI PDV as you can get even more of those for free! http://www.vexrobotics.com/vexpro/pdv-2016.html |
#11
Spark + PWM Cable + Extra Screws = ![]() If I had to complain about anything on the Spark, the LEDs are very bright. Last edited by RyanN : 19-01-2016 at 13:41. |
#12
I have not seen this mentioned anywhere but another feature unique to the Talon SR/SRX and Victor SP is the smart LED. The led will blink at a rate proportional to duty cycle. A faster blink rate means you are approaching full throttle. I find this feature very useful when trouble shooting control loops without the motor being connected.
#13
This is simply not true. Even according to your own documentation, the Victor SP is lighter. ![]() Paul |
#14
I just took a Victor SP and a SPARK out of their boxes and weighed them.
SPARK + one PWM Cable = 86 gram (0.19 lb) Victor SP (pre-wired with PWM Cable and ~12 inches 12AWG leads) = 104 gram (0.23 lb) Adding a foot of 12AWG* to the SPARK will bring it to about 98 gram (0.22 lb). [edit] Also need to add two crimp rings or forks to the SPARK. Total weights are looking very close. --------- *Wire tables usually indicate about 20 lb per 1000 ft (9 gram per ft) for 12 AWG bare copper wire. Insulation types vary, but about 3 gram per foot is a reasonable guess. Last edited by Richard Wallace : 19-01-2016 at 08:54. |
#15
Thanks for reminding me that our chart needed to be updated, we fixed the text spec on the page soon after launch, but I forgot about the chart. I have removed the old one, the new one is below. I also removed the weight from the SRX, as that data was not available online either. ![]() |
