Re: Ball bouncing out of the high Goal
I wish FIRST had modified the goals to reduce or eliminate bounce-outs early in the season. I think it is a bit late to do it now. Although the definition of a "scored boulder" addresses bounce-outs, I really hope that FIRST didn't intend to see this many. In an ideal world, you get credit for putting the boulder in the goal and not just for doing it with some preferred trajectory.
We have struggled with bounce-outs, but of a different sort. We shoot a high angle shot from the batter (like a lot of other teams), and unless we hit the top of the window, the backspin on the ball makes it roll down the chains, bounce off the framing at the bottom of the angled face of the castle, and then out. |
In the real world, you get credit for finishing the job you are asked to do. In this case, your true objective is not really to get the Boulder to enter the opening of the Goal. It is to get the Boulder to trip the Counting Mechanism that is several feet below the opening of the Goal. As Andrew stated, "Field is working as designed and spec'd." This means that certain solutions will work successfully and others will not. It is up to those competing in this game to find the solutions that do work. |
We just don't shoot such that our (nearly 45 mph velocity) shot trajectory is perpendicular to the back board and we've stopped having bounce outs. Every shot that we took that went into the high goal at our state championship event stayed in.
This isn't just a FIRST lesson, it's a life lesson. A lot of times you just have to play with the cards you've been dealt and do your best despite unanticipated challenges. Last edited by BoilerMentor : 18-04-2016 at 15:49. |
At least this year it's really difficult to overfill the goal. I'm interested to see the return of the pokey stick from 2012.
Thanks for the help. Yes we will be shooting with less force so hopefully that will not be an issue.
Also, the backboard will also absorb some of the impact as shown here
#10
There were a couple of matches at Vegas where balls would accumulate on the shelf inside of the goal. After the first occurrence, volunteers would be behind the tower waiting with the stick used to haul defenses around. These matches were definitely fun to watch.
#11
I have lost count of how many balls we have had pop out. Still less than a dozen overall though I think. We do have a fairly strong shot. I think you just shrug and focus on getting those points back. I don't really think it is something that the GDC can completely eliminate. The chains certainly help. Most of the time I think, as someone mentioned, our shots just rolled across the back and out.
