Go to Post I fear sometimes as time increases between the present and when someone started, some sight of just how hard it can be to field a functioning robot for a young team is lost. - xForceDee [more]
Unread 18-01-2016, 17:18
team_3494 team_3494 is offline
FRC #3494
team_3494 is an unknown quantity at this point
Question Eclipse changing project type to FRC project
We imported a project from github as a generic project in eclipse. Now we need to change it to a FRC/WPIlib project. Does anyone know how to do this?
Unread 18-01-2016, 19:08
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Eclipse changing project type to FRC project
Close eclipse, then open your project's ".project" file in a text editor. Under <natures> add
Code:
<nature>edu.wpi.first.wpilib.plugins.core.nature.FRCProjectNature</nature>
Then start eclipse again and it should be a wpilib project.
Next time you import something from github, choose the "New project wizard" option and make it a wpilib project directly.
Unread 21-01-2016, 19:18
FRC #3494
Smile Re: Eclipse changing project type to FRC project
Code:
Thanks, doing that worked just fine for us.
