Go to Post H.A.T.E.R.S. = Having Anger Towards Everyone Reaching Success - pandamonium [more]
Unread 18-01-2016, 17:35
johnny_Bet johnny_Bet is offline
Dark Lord of Code
AKA: Johnny Bettencourt
FRC #4643 (Thunderbird Robotics)
Rookie Year: 2015
johnny_Bet is infamous around these parts
Wink Motor Twitch...
Hello people of Chief Delphi! I'm the programmer for team 4643. We are experiencing difficulties with twitching motors. When code is disabled the motors don't twitch, leading me to conclude that it's a programming issue. I will be putting my code on github soon as well as a link to the repository but I can't right this second. Any help is appreciated!
Unread 18-01-2016, 17:41
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Motor Twitch...
Are you controlling your motors via PWM or CAN? Poorly wired robots can occasionally generate or pick up electrical noise that can make PWM controlled motors twitch.
If it's not electrical, then the next most popular option is commanding the motor multiple times in a control loop. As soon as you call motor->Set(x), the output is set. Calling motor-Set(0) later will largely insure that the motor won't move much since the 0 will be active longer, but it could still twitch from the momentary setting to an actual value.
Unread 19-01-2016, 13:39
CryptoStorm's Avatar
CryptoStorm CryptoStorm is offline
EIC Tech
AKA: Joshua Stilwell
FRC #5056 (MegaHurtz)
CryptoStorm is an unknown quantity at this point
Re: Motor Twitch...
what are you using for your user input? You may need to add a deadband for your neutral input.
here are a couple ways:
http://www.chiefdelphi.com/forums/sh...=joystick+dead
