Go to Post One button, ten copyrights, you do the math. - StephLee [more]
Unread 18-01-2016, 17:38
brubakbd brubakbd is offline
FRC #5188
brubakbd is an unknown quantity at this point
Labview & Github
I'm a mentor for team 5188 and this year we want to try to organize our code revisions better, so obviously github is the solution we came to. But I'm not quite sure how to integrate the two as I'm not familiar with git myself. Has anyone gotten a nice setup for this or know of any good tutorials for setting it up? Thanks!
Unread 18-01-2016, 17:47
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
Rookie Year: 2011
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
Re: Labview & Github
There really is no "good" implementation of git and LV. You can't diff LV files. Period. But that doesn't mean version control isn't useful. You should always use version control. Just keep in mind that you can't merge LV files, only overwrite them.
2015 MAR District Champions
Unread 19-01-2016, 15:43
Philip Arola's Avatar
Philip Arola Philip Arola is offline
You can check out any time you like
AKA: KG7VAM
FRC #1510 (Wildcats), FRC #2898 (The Flying Hedgehogs)
Rookie Year: 2012
Philip Arola is an unknown quantity at this point
...except for with the diff/merge tools Labview comes with.
You can define these as the diff and merge tools when using command line git, and possibly for only .vi files; I have not worked out the latter yet.
Cunningham's Law: The best way to get the right answer on the Internet is not to ask a question, it's to post the wrong answer.
Unread 19-01-2016, 23:07
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
My team has used Tortoise Git in the past (which also supports customizing the diff and merge tools to use the LabVIEW provided ones), the tutorial we used to use is no longer online, but this project on Bitbucket is specifically supporting Tortoise Git working with LabVIEW
Unread 20-01-2016, 17:13
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
Rookie Year: 2013
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
My team is using TortoiseGit + GitHub with LabVIEW. The main thing for LabVIEW is to set up the diff and merge tools which actually work pretty well. Here's how:
In the settings menu, there's an area for diff view and merge tool. Set an external diff tool like this:
The location for diff tool should be:
C:\Program Files (x86)\National Instruments\Shared\LabVIEW Compare\LVCompare.exe
Do the same for merge tool, and the location for that is:
C:\Program Files (x86)\National Instruments\Shared\LabVIEW Merge\LVMerge.exe
Head Programmer / Driver
Unread 18-01-2016, 18:14
phurley67 phurley67 is offline
Programming Mentor
FRC #0862 (Lightning Robotics)
Rookie Year: 2013
phurley67 is an unknown quantity at this point
I find labVIEW and version control to be a real pain. That said it does come with lvcompare, which does work.
Unread 19-01-2016, 08:34
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
GitHub is fully compatible with Subversion. We use TortoiseSVN to version control our stuff on GitHub.
If you install at the VI Package Manager, there is a TSVN plugin for LabVIEW.
http://www.viewpointusa.com/product/.../tsvn-toolkit/
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
