Go to Post Rule 1. Never take Dave's hint's seriously. Rule 2. Watergame. - AndyB [more]
Unread 18-01-2016, 19:17
staplemonx's Avatar
staplemonx staplemonx is offline
The Idea Guy
AKA: JJ Biel-Goebel
FRC #1389 (The Body Electric)
Rookie Year: 2011
staplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond repute
Driving up the portcullis
Has anyone tried driving your robot up to the portcullis and putting a driven wheel in contact with the gate, then driving the gate up and the robot under?
crazy engineer
www.jjbiel-goebel.com
helping team 1389
http://team1389.com/
Unread 18-01-2016, 19:34
Robomarfa Robomarfa is offline
FRC #5771 (Robohorns)
Team Role: Teacher
Rookie Year: 2015
Robomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to all
Re: Driving up the portcullis
Have not tried. How do you get a drive wheel in front of your bumper?
Unread 18-01-2016, 19:36
tindleroot tindleroot is offline
Free Scouting Help to All
AKA: Casey LeeVan
FRC #4272 (Maverick Boiler Robotics)
Rookie Year: 2007
tindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond repute
A driven wheel is a wheel powered by a motor. Such a device would be allowed as long as it is not extended horizontally more than 15" beyond the frame perimeter and is not extended above the height limit of the robot.
2012-2013: FTC 4601 (student)
2014-2015: FRC 135 (student) - 5 banners in 2 years!
2016-present: FRC 4272 (mentor)
Thanks to all of our alliance partners!
11, 51, 68, 201, 234, 868, 1108, 1241, 1760, 3147, 3301, 3487, 3865, 4269, 4485, 4580, 5188
Unread 18-01-2016, 20:37
1452-Leo 1452-Leo is offline
FRC #1452 (Omnicats)
Rookie Year: 2014
1452-Leo is an unknown quantity at this point
We built a portcullis out of wood (built to the "Team Version" specifications) and I don't think it would be possible to roll it up. However, the actual one might have less friction when applying a force perpendicular to the lexan, so it might be easier.
Unread 18-01-2016, 21:05
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
The portcullis uses ball bearings at the top and bottom of the door in a steel track. So even with huge side loads there should be very little friction(page 253 of 2016FieldComponents.pdf)
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 18-01-2016, 21:11
Bob Steele's Avatar
Bob Steele Bob Steele is offline
On the RIBMEATS bandwagon....
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
bearings at the top and bottom... Not sure i understand...
Do you mean the top and bottom of the sides? Probably ...
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 18-01-2016, 21:19
RoboChair's Avatar
Yes, on the sides in a steel track. Consult the 2016FieldComponents.pdf for a visual of the Portcullis as you will see at competition.
Unread 20-01-2016, 07:12
StephenNutt StephenNutt is offline
FRC #0172 (Falgor)
Rookie Year: 2007
StephenNutt is an unknown quantity at this point
We've had the same idea too. There are ball bearings on the sides at the top, and I believe a wheel at the bottom that will roll along a track.
You should allow for more than 5lbs of force - motors should generally be run at under 50% of maximum torque and you should account for some friction too.
Please post back and let me know how things work for you.
Unread 20-01-2016, 07:26
TheGabe's Avatar
TheGabe TheGabe is offline
FRC #1259 (Paradigm Shift)
Team Role: CAD
Rookie Year: 2013
TheGabe is an unknown quantity at this point
Our team tried this. We have a few of the four inch anymark wheels (checkered tread) on the frount of our intake mechanism. We decided to try it. Only about half of the wheel is exposed toward the gate so we were able to roll the gate up and it rested on top of our wheels. From there we lifted the intake mechanism up and drove under. Our portcullis is made out of wood and has the 5lb lift force. This is how we plan on tackling this defence during competitions.
Unread 20-01-2016, 08:30
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Great to hear it! We're also planning to double-duty our intake rollers to raise the portcullis. Better go back and check the forces, though!
