Go to Post FIRST rocks, thats for sure. - Dan Richardson [more]
View Poll Results: What do you plan to do for your "go-to" autonomous routine?
Watch other robots do their thing. 4 1.99%
Reach a defense - any defense from any position!) 1 0.50%
Score a boulder in the low goal - if starting as the spybot. 0 0%
Score a boulder in the high goal - if starting as the spybot. 4 1.99%
Cross a defense - but it has to be a specific one. 2 1.00%
Cross a defense - anything we can drive over/under will do. 30 14.93%
Cross a defense - And we'll open a door to do it. 1 0.50%
Cross a defense - you name it, we can cross it. 6 2.99%
Cross and score low: if we have the right defense. 4 1.99%
Cross and score high: if we have the right defense 17 8.46%
Cross and score low: Any defense we can drive over/under 15 7.46%
Cross and score high: Any defense we can drive over/under 55 27.36%
Cross and score low: Opening a door in the process. 1 0.50%
Cross and score high: Opening a door in the process 2 1.00%
Cross and score low: Any defense will do. 4 1.99%
Cross and score high: Any defense will do. 28 13.93%
Score two boulders high and cross - gotta have the right defense 8 3.98%
Score two boulders low and cross - gotta have the right defense 0 0%
Score two boulders high and cross - can do it with more than one defense 14 6.97%
Score two boulders low and cross - can do it with more than one defense 2 1.00%
It doesn't score any points, but it's still cool... 3 1.49%
Voters: 201. You may not vote on this poll
Unread 18-01-2016, 20:50
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
Team Role: Teacher
Rookie Year: 2011
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
What are you planning for Autonomous?
Okay, we are better than a week in and I am guessing that most teams have a pretty good idea what they are trying to accomplish... So, if all goes to plan, what sort of autonomous routine will you likely be sporting as your "go-to" routine?
Unread 18-01-2016, 20:57
Aaron (Awe-Sum)'s Avatar
Aaron (Awe-Sum) Aaron (Awe-Sum) is offline
4961 Strategy/Scouting Mentor
AKA: A-A-Ron
FRC #4961 (Shock and Awe-Sum)
Rookie Year: 2014
Aaron (Awe-Sum) is an unknown quantity at this point
Re: What are you planning for Autonomous?
Our goal with the robot in general was to overcome all defenses aside from the low bar, while also being able to shoot high goals.
This will allow us a lot of freedom during Autonomous mode. We plan to traverse either the defense in slot 3 or slot 4, then shoot a high goal.
2014: Howell Highest Rookie Seed
2014: Howell Rookie All-Star
2015: Centerline Quality Award
Unread 18-01-2016, 21:00
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
I rather suspect that we'll be using sensors to collect data about our environment, then discarding that and driving straight into the nearest Defense or Shield, whichever is handiest.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 18-01-2016, 21:38
Abhishek R Abhishek R is offline
Rookie Year: 2012
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Originally Posted by EricH View Post
I rather suspect that we'll be using sensors to collect data about our environment, then discarding that and discarding straight into the nearest Defense or Shield, whichever is handiest.
I prefer the guardrail. It's more exciting for the audience and/or referees.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 18-01-2016, 21:47
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Risk of being disabled if you extend out and hit something, though.
Past teams:
Unread 18-01-2016, 21:55
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Rookie Year: 2013
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
We plan to have at the minimum an auto that will score in the high goal from the spybot position for our week one event, but at the same time be midway developing our autonomous that can cross and score for our week 3 event (hopefully).
So, because it isn't possible to select multiple choices, I'll go with "none of the above"
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 18-01-2016, 22:18
TJP123 TJP123 is offline
AKA: Tom Pospeshil
FRC #0503 (Frog Force)
Team Role: Coach
Rookie Year: 2012
TJP123 has much to be proud ofTJP123 has much to be proud ofTJP123 has much to be proud ofTJP123 has much to be proud ofTJP123 has much to be proud ofTJP123 has much to be proud ofTJP123 has much to be proud ofTJP123 has much to be proud ofTJP123 has much to be proud of
I didn't see an option to vote for "Get beached on the nearest defense, then fling a ball aimlessly."
Unread 18-01-2016, 22:32
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Rookie Year: 2011
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Current plan: Cross either category A defense (Cheval de Fries or Portcullis) or low bar
Reality: Spin around in a circle? Run backward into the other alliance's robots? Do a sick jump off of the rampy defenses and/or over the guardrail? Honestly, who knows?
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 23-01-2016, 17:20
Pirateninja1234 Pirateninja1234 is offline
FRC #2557
Pirateninja1234 is an unknown quantity at this point
Post Re: What are you planning for Autonomous?
How do you plan on crossing the chill de fries?
For the question my team plans on a 20 pt. autonomous to cross any defense and aim and shoot into the high goal. Then opening either the sally port or the drawbridge at the end of the autonomous period.
Programmer for 2557.
Unread 23-01-2016, 19:52
bmire3206's Avatar
bmire3206 bmire3206 is offline
FRC #3206 (Royal T-Wrecks)
Team Role: Mechanical
Rookie Year: 2014
bmire3206 is an unknown quantity at this point
my team is planning that we change it on the dashboard prior to the match to change it based on our alignment.
Unread 23-01-2016, 20:28
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
We plan to drive up roughly centered on the plank to the right as the robot views it, then lower our ball pickup, which has a portion that goes essentially to the floor. Then we'll just drive over the adjacent planks. Probabaly not necessary, but we will have a skid plate between our inner plates (highly modified KoP 2015 chassis).
Unread 23-01-2016, 20:33
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
Our current plans involve the robot traversing a defense, and then using sensors and vision tracking to score high. I might suggest the additional pathing back towards the defenses or over them to prepare to continue our assault of the defenses once auto ends.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
"Head Bot Coach" FRC Team 4901 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1102, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 24-01-2016, 00:31
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
I accidentally read this as....
Chili Fries.
I think we have this year's food reference.
Past teams:
Unread 24-01-2016, 00:49
Chili Fries.
I legit read it the same way.
John Fogarty
  #15   Spotlight this post!
Unread 24-01-2016, 04:51
Turing'sEgo Turing'sEgo is offline
Rookie Year: 2010
Turing'sEgo can only hope to improve
Prediction: More than half the balls in the center of the field will be scored in autonomous on Einstein. It'd be cool to see robots use vision to adapt to which balls remain.
