Re: Velcro for electrical components
We personally stick to zip ties except on the radio where we use Duralock.
In addition, the more electrical components are allowed to move/shake, the more likely they are to disconnect. Added strain on wires and connectors can make a bad crimp fail or a spring-loaded connector release a wire. If I were inspecting robots, I would not pass anyone who used only "fuzzy" Velcro to attach their electronics. If "industrial" Velcro was used, I would spot check the components and make sure that nothing was in danger of failure. |
As far as I can recall, we have bolted down nearly all our electronics, with the exception of last minute gadgets.
If you cannot drill into the surface, VHB is one of the most annoyingly powerful adhesives I've ever had the pleasure of using. Which, coincidentally, is included in the KoP this year. |
One year we held the battery in with Velcro (actually hook & loop, but Velcro is shorter to type). No issues with them coming loose even with the robot upside down. They where difficult to change. I wouldn't recommend it. We continue to use a Velcro strap to secure the battery. We use Velcro to hold the radio. No issues ever even with inspectors.
I do perform FRC inspections. You don't fail robots for poor design choices except for where that design choice violates a specific rule. Like using hook & loop tape on bumpers. Using Velcro for securing things may or not be a good design choice depending on the application. |
