G43 Clarification
I'm fairly new to First and am a little unclear about the wording of the foul for G43 -
Violation: FOUL. For every five (5) seconds in which the situation is not corrected, FOUL Does this mean that contact that lasts for just a second or 2 would not be a Foul? It would be "corrected" (i.e. drive away) in under the 5 seconds which would appear to be the threshold for the Foul to be called. If not, why the wording which includes the 5 second count? I recall in 2014 refs counting out the "pin" times before calling the Foul, is rule the same or different? |
Re: G43 Clarification
Pinning is a bit different in that the first FOUL occurs 5 seconds in. So, take care around your own OUTER WORKS when opponents are near. |
So first contact is an immediate foul, with an additional foul every 5 seconds thereafter if you continue contact....makes sense. Thx
Not just contact, but impede or otherwise restrict them from the outer works. The blue box is specific and particularly strict.
Given how the blue box is worded, I believe the first interaction is a foul, no matter what you do to them. If you pin them or interact with them more, its a foul per 5 seconds of interaction.
