Go to Post As long as this is a competition teams will push the limits. Those that succeed are those who can push the envelope and still stay within the lines. - Steve W [more]
Unread 19-01-2016, 16:51
2386programming 2386programming is offline
FRC #2386 (Trojans)
Rookie Year: 2011
2386programming is an unknown quantity at this point
LabView SmartDashboard
So here's the problem. I am trying to display the current angle from our gyro sensor on the smart dashboard, but when I open the driver station, and select LabView as our dashboard type, the dashboard does not open.... Any Ideas?
Unread 19-01-2016, 17:27
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Re: LabView SmartDashboard
Try running as Admin?
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 20-01-2016, 08:23
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
You might check to make sure you have a Dashboard installed. It should be at:
C:\Program Files (x86)\FRC Dashboard\Dashboard.exe
or something similar. Once you find it, try double-clicking Dashboard.exe just to make sure it is working.
Doug Norman
Unread 22-01-2016, 11:17
aeastet aeastet is offline
Programming Mentor
AKA: Tim Easterling
FRC #6043 (Allegan Tigers Robotics)
Team Role: Coach
Rookie Year: 2011
aeastet is an unknown quantity at this point
Did you build it. In your dashboard project you will need to build the dashboard after you make changes to it.
