Go to Post You know what they say, the mind is the second thing to go and I can't remember the first. - GaryVoshol [more]
Unread 20-01-2016, 15:35
dpotteiger dpotteiger is offline
FRC #2377
Rookie Year: 2015
dpotteiger is an unknown quantity at this point
Guidance For Approach To Feed Video Stream From Raspberry Pi With HD3000 To Dashboard
Has anyone tried sending MJPG video from a Raspberry Pi to the Dashboard?
We are developing our robot to use a single USB HD3000 camera. The camera is connected to a Raspberry Pi running Python along with OpenCV support. Our thought is to send the camera frame data to both our image processing logic and the dashboard. We can send it through the Roborio but it appears we would have to modify the Camera Server code somewhat. We were planning on connecting the Pi to a the on board Ethernet, so we had another thought to pipe it to the dashboard directly. Thank you in advance for your thoughts.
Unread 20-01-2016, 16:06
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Rookie Year: 2010
adciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to all
Re: Guidance For Approach To Feed Video Stream From Raspberry Pi With HD3000 To Dashb
You can modify the dashboard code to point to the Pi instead of the RoboRIO (not sure what language you're using). You'll need to have the Pi transmit the images as the driverstation is expecting.
The dashboard is expecting to read a 4 byte value coresponding to the length of the image and then received a JPG which is that value in length. Alternatively you could write your own receiver.
Originally Posted by texarkana View Post
I would not want the task of devising a system that 50,000 very smart people try to outwit.
Unread 20-01-2016, 23:33
FRC #2377
Rookie Year: 2015
Thank you for your reply. We were definitely considering this approach... Our native code on the Robot is Java. We are using the Smart Dashboard. Any thoughts how to modify Dashboard code?
Unread 21-01-2016, 06:45
One Eyed Man
Rookie Year: 2010
Unfortunately I don't use Java (LabView team). At worst, you could open a port in Java to connect to the Pi and display the image in a popup window. If you post a copy of the stock default Java dashboard I may be able to find the setting.
Unread 25-02-2016, 07:28
coyotepod coyotepod is offline
FRC #3603 (Cyber Coyotes)
Team Role: Teacher
Rookie Year: 2015
coyotepod is an unknown quantity at this point
I'd love to learn more about this! Any updates or tutorial suggestions for pi and JAVA communication? We are new to JAVA this year (Iterative but considering Command Base). We have a pi and HD3000 but don't yet know how to stream a video to the Java dashboard.
Unread 25-02-2016, 09:41
DubstepLion1's Avatar
DubstepLion1 DubstepLion1 is offline
FRC #5518 (Techno Wolves)
Team Role: Leadership
Rookie Year: 2015
DubstepLion1 is an unknown quantity at this point
There is a plugin available for the SmartDashboard. Put the jar folder in the C:\Users\[USER]\SmartDashboard\extensions folder (on Windows). You should be able to add the extension and edit its properties such as the IP address and port number.
