Go to Post If it's the loss of American lives that concerns the nation, why not campaign aggressively against smoking, or improve automobile safety? At least then, the benefits will be tangible, and substantially more significant to the well being of the locals. - Tristan Lall [more]
Unread 20-01-2016, 19:40
Massako Massako is offline
FRC #5725 (Cerberus)
Team Role: Leadership
Rookie Year: 2015
Massako is an unknown quantity at this point
6 Cim Drive-Train
Would a 6 sim drive train with an overall gear ratio of 19.64:1 and 8 inch wheels be an ok setup for this years game. esimateing the total robot weight at 120 just to be safe. one issue we though of was the current and if it would exceed the limit and if that is the case what would be an ok substitute. instead would it be a better idea to run with the same overall gear ratio and use a 4 cim drive train instead?
Thanks
Unread 20-01-2016, 19:55
Procolsaurus's Avatar
Procolsaurus Procolsaurus is offline
AKA: Robert Pond
FRC #4118 (Roaring Riptide)
Rookie Year: 2011
Procolsaurus is just really niceProcolsaurus is just really niceProcolsaurus is just really niceProcolsaurus is just really niceProcolsaurus is just really nice
Re: 6 Cim Drive-Train
The max robot weight is really 120lb for the robot + 14lb for the battery + 11lb (can legally be up to 20lb) for the bumpers.
2011-2012 Team 180 student
2014-Now Team 4118 College Mentor
2014 Referee, 3 events
2015 Field Reset, Referee, Scorekeeper
Unread 20-01-2016, 20:00
Rookie Year: 2015
I know and i expect it to be higher i was just wondering if that would be a usable solution.
Unread 20-01-2016, 20:08
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
What is your wheelbase and track width?
What other motors will you be running simultaneously with your drive system?
Are you going to be using a compressor?
Are you going to monitor your voltage in any fashion?
Are you going to dampen your acceleration with your software?
Being correct doesn't mean you don't have to explain yourself.
Unread 20-01-2016, 20:15
Rookie Year: 2015
we will msot likely be useing 2 or 3 bag motors and a mini cim. no compressor and we will have the max speed reduced in software. voltage monitoring will be done just in drive station.
Unread 20-01-2016, 20:11
Breadbocks Breadbocks is offline
FRC #1002
Breadbocks is on a distinguished road
You can run the exact numbers in the JVN spreadsheet, but when I was looking at a 10:1 ratio on a 6 CIM drive train pushing match I couldn't break 80A of current. Unless you get into a pushing match and try to shoot the ball and climb all at the same time you probably won't break 120A.
The bigger concern should be battery life, which you'll be best suited to figure that part out yourself. 6 CIM is definitely a possibility, teams have done it before, but what your specific design winds up being will decide whether your battery can handle it.
Unread 20-01-2016, 20:29
Rookie Year: 2015
i put all those numbers in a swell and i got 38.35 pushing amps per motor.
Unread 20-01-2016, 20:43
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
FRC #1771 (N. G. R.)
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
WithThe battery's legal for first use I personally see no scenario where 6 cim drive does anything but hurt your performance. The internal resistance of the battery is too high, the voltage drop causes too many issues. 2 speed transmissions do more then enough. The greater benefit is a good automatic shifting algorithm.
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014- Future
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 20-01-2016, 20:56
Rookie Year: 2015
so then would a 4 cim drive train with the same overal gear ratio be a better solution
Unread 20-01-2016, 21:47
cmwilson13's Avatar
yes. i might speed it up a little bit, but with the obstacles on the field the extra power can be beneficial
Unread 20-01-2016, 23:54
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Those would be issues regardless of the number of CIMs, if I'm not mistaken. I always took away that a 6-cim could push harder and accelerate faster. They risk brownouts for the extra current draw.
If you gear your drivetrain down that much, there is little or no purpose I can see to having a 6-cim over a 4-cim.
<Now accepting CAD requests and commissions>
Unread 21-01-2016, 00:06
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
We had a 6 cim drive base and a fly wheel one year it was always interesting seeing the lights being slightly dimmer when the flywheel was fully rev'd and we were traveling at full speed.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
