Go to Post You know you are a true tech geek when you end up on top of the Sears tower, and the only pictures you post are the ones of the radio antennae. ;) - Tom Line [more]
Unread 20-01-2016, 19:55
Brian Michell's Avatar
Brian Michell Brian Michell is offline
Timelord and programmer
FRC #5416 (TaRDIS)
Rookie Year: 2015
Brian Michell is an unknown quantity at this point
KOP Drivetrain modification
Hello everybody. Our team is (quite a bit) behind in the 6 week build phase of the competition and we have yet to select a drivetrain that we can get our hands on (eg. Rhino tracks, 8" pneumatic wheels, ect.) so I have taken the task to try to come up with designs that use the KOP wheels along with the drivetrain we have. My question is if there is any relatively easy way to remove the end plate. We would obviously have to include bumpers and something to cover the 2 side plates.
As a programmer with little technical knowledge in this field I may not be able to answer many questions you have but I will pass this thread on to the build members of the team if any questions I can not answer arise.
Thanks in advance!
Unread 20-01-2016, 22:34
Billfred's Avatar
Billfred Billfred is offline
Re: KOP Drivetrain modification
Sure! Just tie it together with something else (and more than we used on the Robot in 3 Days robot, because that frame is now a little bent up since we had and open front and minimal bellypan on it).
Unread 21-01-2016, 00:32
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
Team Role: Coach
Rookie Year: 2012
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
These work well if you have several http://www.andymark.com/product-p/am...m?1=1&CartID=0
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 21-01-2016, 07:50
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
The chassis (if you built it according to directions) is just bolted together. The end plate is held on with 10-32s. You should be able to take it apart easily.
Cross-braces can be made easily with angle aluminum, or even more easily and consistently using versaframe tubing (I'd recommend the 0.1" thick for this). As Billfred noted above, a rigid belly pan would be a must to keep the frame square.
