Go to Post We learn from our failures, but our successes reinforce what we've learned. - Mike Ciance [more]
Unread 20-01-2016, 20:06
mentos54 mentos54 is offline
FRC #0247
mentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to beholdmentos54 is a splendid one to behold
Angle of ramps?
While trying to calculate some lengths for our robot, we had to deal with the angles on the ramps to the defenses. In the rulebook, the ramps are at a 13.5 degree angle, with a 3 inch height and a 12 inch hypotenuse. After trying to figure out how to work with this, we realized that it's impossible. However, in the solidworks model, it has a 14.5 degree angle (which does work). Am I safe in assuming we should use this, instead of the rulebook? And has anyone else found similar mistakes?
Unread 20-01-2016, 20:17
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
Team Role: Teacher
Rookie Year: 2011
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Angle of ramps?
The dimensions in the manual don't seem to match 100% what the field drawings and on-field measurements give. Check out other posts about this.
Are you having trouble CADing the parts, or making a robot that can go up 13.5deg?
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 21-01-2016, 07:34
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Angle of ramps?
If you take the thickness of the sheeting into account, you can get much closer to this angle. Working backwards, A 12" hypotenuse at 13.5 degrees would be 2.88" off the floor at the high end.
Also remember that the field NEVER matches the drawings to within stated tolerance. Especially if you design specifically for it.
