Go to Post You pick the best person for the job whether they are black, white, asian, hispanic, female, or male; NOT so you 'look good' when they publish your team picture in the school paper, but because they can get the job done right, on time, with a passion. - Pavan Dave [more]
Unread 20-01-2016, 23:25
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Victor SP Issue, Defective?
I was wondering if anyone had seen a similar issue we experienced testing our drive system the other day:
We are testing a 6-CIM drive (using 3-CIM Toughbox). This was a no-load test (free-spinning driveshaft). Each CIM is run using their own VictorSP.
At low rates everything works as expected, but once I ramp up, one of the VictorSPs transitions from blinking green (positive direction signal) to blinking orange and effectively stalls the gearbox. As expected this also pulls a ton of current (large drop in battery voltage).
I swapped PWM channels for 2 of the SP's on the same gearbox, but that same speed controller was having problems (the other SP's were running fine). I removed the PWM for the problem SP and ran the other 2 SP's to full power with no issues (3rd motor was essentially in coast).
Is this speed controller defective? I believe this is one we got from the VEXPro voucher.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 20-01-2016, 23:30
Clayton Summerall's Avatar
Clayton Summerall Clayton Summerall is offline
Mentor
FRC #4587 (Jersey Voltage)
Rookie Year: 2011
Clayton Summerall is on a distinguished road
Re: Victor SP Issue, Defective?
Try doing this with 2 cims and see if you get the same result.
Unread 21-01-2016, 00:08
MetaEngineer's Avatar
MetaEngineer MetaEngineer is offline
Director of magic smoke
AKA: Barden
FRC #0246
Rookie Year: 2010
MetaEngineer is an unknown quantity at this point
Try the questionable speed controller by itself with the other motors on the gearbox disconnected and coasting. Also try it in reverse direction under the same conditions.
Use a voltmeter to look at what the output of the speed controller is doing when it acts up.
Unread 21-01-2016, 07:27
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
Rookie Year: 2012
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
Before giving up on that Victor SP I would run the calibration procedure on it. To me it sounds like it's seeing a pulse width outside its expected range.
Unread 21-01-2016, 07:47
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
This actually sounds like a mechanical problem. Don't discount the possibility of a drive train locking up and stalling the motors.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 21-01-2016, 07:51
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
Please check to make sure that all of the motors are spinning in the same direction. At low speed you may not see it as the other motors may be able to overcome the one going in the opposite direction.
The way we do this on our team is to connect each motor one at a time to verify it spins the wheels in the same direction as the others.
This is usually what happens when we see this phenomenon.
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
