GRIP on an NVIDIA Jetson TK1
Can someone explain or link me to me the steps I should take to
1. Deploy a GRIP pipeline to an NVIDIA Jetson TK1 2. Use a camera (preferably USB) plugged into the roboRIO as an input 3. Access the published values from a roboRIO running Java Is this even possible? |
Re: GRIP on an NVIDIA Jetson TK1
Thanks for posting this, I'm also very interested in the Jetson+GRIP scenario, and eager to hear others' experiences/insight there.
It seems like this is possible, but I'm not sure all the connective tissue has developed yet. This thread on GRIP's Github relates to getting GRIP running on Raspberry Pi 2, which is the same ARM architecture as Jetson. Last night I installed java 8 on the Jetson, and tried to run the Linux ARM build of the GRIP .jar file provided here (via that Pi thread by user "multiplemonomials"). This started without any architecture/platform errors, but threw an exception about missing some libs, such as NetworkTables. A build of those libs was posted here, which might fix that issue, but I have not had a chance to try them. I haven't done much yet with an actual camera. I have an older Logitech that the Jetson recognizes as a USB device, but that's as far as I've gone. I have a newer Logitech C920 on order that's confirmed to work on Jetson, but I don't yet know if that will still require installing drivers, etc. If anyone has more experience with GRIP on the Jetson TK1, please share! |
will using GRIP on a Jetson take advantage of the Tegra hardware, or will it just use the ARM processor (making it an expensive and large rPi)?
The hope is it will use the hardware, but I think that remains an open question.
It will not use the GPU unless it is coded specifically for it and I do not believe GRIP is currently coded for GPUs though I'm not certain. I have not had a chance to play with GRIP yet but I can help answer questions about using GPUs for vision.
I'm not super familiar with the GRIP deploy, but I believe they are packaging some pre compiled OpenCV libraries into their Jar, which means you certainly would not get the benefits of hardware acceleration. |
Check out this webcast/video about porting OpenCV code over to the Jetson: http://devblogs.nvidia.com/parallelf...etson-tk1-gpu/ As far as I know, OpenCV4Tegra is a pre-compiled and ARM/Tegra/CUDA optimized version of the OpenCV library because building it yourself is a pain though definitely doable. Also, OpenCV4Tegra is being augmented/replaced with VisionWorks now on the TX1. *Please note that I could be wrong because I haven't dug into Nvidia's code... just our code that is somewhat based on it/uses it. |
GRIP does not take advantage of the GPU: it uses vanilla OpenCV and JavaCV so it does not know how to use it. What you might be able to do is use GRIP to prototype and fine-tune your vision algorithms (with realtime visual feedback and easy modification) and then move that into a program that takes advantage of the GPU.
FWIW, GPU implementations of many FRC-useful OpenCV functions are available (ex. Color space conversion, thresholding, resizing, binary morphological operations, edge and corner finding, feature finding, filtering, line and circle detection, etc.), and better yet a large number of them support streams (they're non-CPU blocking). However, other bread and butter FRC tools like line segment finding, contour finding, and convex hulls must be done on the CPU (unless you roll your own CUDA-powered version). I would be impressed by any team that finds a way to do the entire goal detection task reliably entirely on the GPU. |
#10
