Go to Post Silly FIRST mentor -- actually spending brain power caring about a sporting event occuring during build season! - Aidan F. Browne [more]
Unread 21-01-2016, 09:37
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
Rookie Year: 2010
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Electric solenoid experience
R29 allows:
Electrical solenoid actuators, no greater than 1 in. stroke and rated electrical input power no greater than 10 watts (W) continuous duty at 12 volts (VDC)
I am curious if anyone has used electrical solenoids and if there is one you would recommend? I see some on McMaster that explicitly list continuous wattage (part weight not listed) and some on Amazon that list weight but not explicit continuous wattage.
Will FIRST accept (continuous duty power) = (nominal voltage) * (max rated current) as an acceptable way to calculate this?
I could only find 1 recent thread on electrical solenoids (plenty for pneumatics), but no feedback on how well it worked. In particular I am curious if these would work for disengaging dog gears (not in a gearbox, and for short periods of time).
Thanks!
-matto-
Unread 21-01-2016, 16:27
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
Rookie Year: 2012
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
Re: Electric solenoid experience
Would power door lock actuators do the job for you?
They're small, inexpensive, and AFAIK, legal under the motor rules (I know they were legal last year). They can push or pull with a surprising amount of force for a $5 mechanism.
http://www.amazon.com/High-Power-Doo...lock+actuators
Unread 21-01-2016, 16:48
AKA: -matto-
FRC #1410 (Kraken)
Rookie Year: 2010
How did you calculate the continuous duty power? I see no data sheet or specs in the amazon link.
Unread 21-01-2016, 17:32
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
I ordered one a few days ago, will report current draw. Couldn't find a spec sheet.
Unread 22-01-2016, 05:56
electroken's Avatar
Electron Tamer
AKA: Ken Pontbriant
Rookie Year: 2012
I didn't, and as they aren't solenoids I don't need to. They are brushed DC motors with a whole lot of gear reduction and a rack and pinion output. These devices are intended to be run for a second or two at a time and will die a miserable death if held in stall, much like a RS-550 motor.
I have a few of them and will measure their current draw under some varying conditions this morning.
Unread 22-01-2016, 08:32
electroken's Avatar
Electron Tamer
AKA: Ken Pontbriant
Rookie Year: 2012
This is for a sample size of two pieces that were in my office. The actuators were clamped down and powered by a bench supply capable of 30A continuous with the output voltage set to 12.0V. Pull force was measured with a gauge that is calibrated once per year, so I trust it.
The two actuators performed identically within my limits of measurement. They stall at a pull force of 18 pounds with a current draw of 4.9 amps. Push force was not measured but should be the same.
I attempted to measure their response time by looking at the current waveform delivered to the motor. Lightly loaded with a compression spring over the output shaft retained by a pin through the clevis, the full-stroke response time is about 80 mS. The stroke length is 0.73".
While not the most scientific of tests, it gives some idea of the capabilities of these devices.
Unread 22-01-2016, 08:43
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
You do realize if they are motors and are not on the approved motor list, they are not legal for FRC use? Just because your inspector missed it doesn't make it legal.
If you don't know what you should hook up then you should read a data sheet
Unread 22-01-2016, 08:46
AKA: -matto-
FRC #1410 (Kraken)
Rookie Year: 2010
This was my thought too - did you replace the internal motor with an RS 550? Else this is not legal last year or this year.
Unread 22-01-2016, 08:50
electroken's Avatar
Electron Tamer
AKA: Ken Pontbriant
Rookie Year: 2012
Nothing has been missed. R29 allows for "Automotive Motors (Window, Door, Windshield Wiper, Throttle)". Under part number it shows "Various".
I've inspected myself for a few years now, and run these devices by several LRIs at events after seeing them on a few machines. The summary of their responses was: If it comes out of a car door, it's OK.
Unread 22-01-2016, 08:58
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
You may want to use OEM parts rather than the generic ones. The generic ones I have purchased for fixing my vehicles have been pretty low quality. You are putting in a lot of time and effort to build the rest of your robot and it would be a shame to see it break down.
At first, the thread title made me think it was about someone wiring their robot while under the influence of mind-altering substances and listening to Jimi Hendrix.
Unread 22-01-2016, 09:01
AKA: -matto-
FRC #1410 (Kraken)
Rookie Year: 2010
Im not sure they are legal this year. See this Q and A. The list in parentheses are the only types allowed. While door motor is allowed, I always took to that to mean the old Van Door opening motors from past KOP (from a mini van door). If these are legal door motors that is fantastic
Unread 22-01-2016, 09:04
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
My mistake. You are correct. Given vagueness of the rule & the literal interpretations the GDC seems to like. I would go with if it comes out of the of a door it's OK.
Unread 25-01-2016, 14:30
https://frc-qa.firstinspires.org/Que...-dp-b0088ye6yq
Unread 25-01-2016, 14:43
AKA: -matto-
FRC #1410 (Kraken)
Rookie Year: 2010
Yay! Legal!
I wanted to be absolutely sure. We had an issue in 2014 with how timeouts worked that required us to show the FTA a Q&A and had it not been so explicit on what was allowed, the FTA would have made an incorrect ruling (he was a real jerk about it too and was bullying our kids).
-matto-
  #15   Spotlight this post!
Unread 29-01-2016, 10:39
MisterG's Avatar
MisterG MisterG is offline
Think twice post once.
AKA: Alan Gilgenbach
FRC #2062 (C.O.R.E. - Community of Robotics Engineers)
Team Role: Team Spirit / Cheering
Rookie Year: 2011
MisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to all
Back to the question by the OP.
These lock actuators look nice but what about an application where the force needed to be applied for longer (say raising a small mechanism and holding it for 30 seconds)?
The solenoid seems like it would be more appropriate for this type of long duty application. Can anyone share legal experience with using electric solenoids on their robot?
Also can someone comment on the rated Volts * rated Amps method to calculate continuous Watts when there is no power specification listed; this seems like it would be accepted at inspection.
Alan Gilgenbach
C.O.R.E 2062
