Go to Post Being a good engineer isn't all about engineering. It's about being able to use engineering for a practical application, and to successfully communicate your research or development results to people who aren't engineers - Jon Stratis [more]
Unread 21-01-2016, 14:16
CryptoStorm's Avatar
CryptoStorm CryptoStorm is offline
EIC Tech
AKA: Joshua Stilwell
FRC #5056 (MegaHurtz)
CryptoStorm is an unknown quantity at this point
How many CIMs in your drivetrain?
I started as a FIRST student in 2004. to my knowledge we've always used 2 CIMS per side on the standard "tank drive" type setup. We used mecanum wheels once which required independent drive of 1 CIM per wheel.
Does anybody have any (scientific) input on using only 1 CIM per side? (2 total)
how about 6 CIM drive?
Unread 21-01-2016, 14:57
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Re: How many CIMs in your drivetrain?
We prototyped a 6 CIM drive during the offseason using VexPro's dog shifting dual-speed gearboxes, and it works fantastically.
We also did octocanum for about five years, and could beast through just about everyone...except for 6 CIM drivetrains, despite being geared down about as preposterously low as you could get, and with great traction.
I would strongly recommend not going to one per side--you'll lose every pushing match you get into with a four-CIM drivetrain, and each of those CIMs are going to draw more current, work harder, get hotter, and drain your battery more than four or six. The only advantage is weight, and it's not a good enough tradeoff.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 21-01-2016, 15:11
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
Rookie Year: 2012
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
has anyone ever done a drivetrain with more than 6 motors? (not including steering for swerve)
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 21-01-2016, 15:37
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Here's a quick calculation using MCALC to compare
one CIM drawing 60 amps at 12 volts
vs
two CIMs each drawing 30 amps at 12 volts:
Code:
Motor Calculator  build MCALC_2014d 2/3/2014 1255pm
Select motor:
1)CIM     6)FP0673   d)FP2719  f)FP9012     g)FP9015    h)FP9013 j)MiniCIM
a)am-0912 b)am-0914  7)DensoL  8)DensoR     c)Denso0160 k)BAG    u)UserDefined
2)RS395   3)RS540    4)RS550   e)RS775-12   5)RS775-18  m)RS555  n)am-0915
r)am-2193 s)am-2235  t)RS390   v)RS545      p)am-2161&2194
w)VEX2177hi  z)VEX2177std  1
CIM FR801 001, AM802 001A @ 12.00 volts:
@ free (no load):
   oz-in      Nm     rpm    rpm%    amps   watts out  watts heat    eff%
     0.0   0.000    5310   100.0     2.7         0.0        32.4     0.0
@ stall:
   343.4   2.425       0     0.0   133.0         0.0      1596.0     0.0
@ max power:
   171.7   1.212    2655    50.0    67.8       337.1       477.1    41.4
@ max efficiency:
    42.8   0.302    4648    87.5    18.9       147.1        80.2    64.7
Select input:
1)oz-in  7)watts_in    3)rpm    5)amps   b)rpm&amps  8)eff%
2)Nm     6)watts_out   4)rpm%   9)volts  a)rpm&ozin  m)main menu   x)exit 5
enter amps: 60
   151.0   1.066    2975    56.0    60.0       332.2      387.8    46.1
Select motor:
w)VEX2177hi  z)VEX2177std  u
Enter the following motor specs in the order and units indicated,
separated by spaces or tabs:
volts   stall_ozin      free_rpm        stall_amps      free_amps
12       686.8           5310             266            5.4
UserDefined-> 12.0 686.8  5310 266.0  5.4 @ 12.00 volts:
@ free (no load):
     0.0   0.000    5310   100.0     5.4         0.0        64.8     0.0
@ stall:
   686.8   4.850       0     0.0   266.0         0.0      3192.0     0.0
@ max power:
   343.4   2.425    2655    50.0   135.7       674.2       954.2    41.4
@ max efficiency:
    85.6   0.605    4648    87.5    37.9       294.3       160.4    64.7
Select input:
enter amps: 60
   143.9   1.016    4197    79.0    60.0       446.6       273.4    62.0
one CIM drawing 60 amps at 12 volts:
332 watts output mechanical power
388 watts waste heat
447 watts output mechanical power
273 watts waste heat
Unread 21-01-2016, 16:44
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
We did a 2 CIM drivetrain last year, but Recycle Rush was definitely a special case; you didn't want to accelerate quickly or drive very fast. We're starting with 4 this year, and if we change it, we'll be going to six.
I've read about people considering 4 CIM + 4 min-CIM designs for Mecanum and 4-wheel Killough, but was unable to find any examples that had been built and played.
Unread 21-01-2016, 17:29
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
Rookie Year: 2011
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Here you go
That year we ran 4 CIMs + 4 Mini-CIMs in our shifting 8in Mecanum Drivetrain. Looking back, mecanum probably wasn't the best choice that year with the heavy defense (), but we sure tried our hardest to make it work. For the most part it did, and we were able to handle many defensive situations with the great traction of the extremely wide wheels, but the cons far outweighed the benefit.
With 8 CIM-motors, we had the potential to run 320 Amps of current into our drivetrain before any of the individual 40A breakers would trip. Even operating well below that, there was incredible risk for popping the main breaker, not to mention browning out components, both of which happened in matches on multiple occasions. In high gear, any defensive situation was almost always a brown-out and radio reboot on the field. In low gear, we had maybe 10 seconds before a brown-out. With the current sensing capabilities of the new PDP, careful software could allow a team to more safely run this kind of setup, but back then, it was far more risk than the team could effectively manage or I would ever recommend.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 21-01-2016, 22:16
EIC Tech
We talked about using 6 cims for a all terrain off season robot. I've got a couple 36v motors I'm going to donate though.
The team is considering 2 CIM drive this year. I'm not recommending that, especially with tank treads. I think they will change their minds when they see how poorly it performs after the chassis is built. Hopefully we can drive it this weekend.
Maybe I'll be proven wrong though..
Unread 21-01-2016, 22:56
EIC Tech
vs
Code:
Select motor:
@ free (no load):
@ stall:
@ max power:
@ max efficiency:
Select input:
enter amps: 60
Select motor:
@ free (no load):
@ stall:
@ max power:
@ max efficiency:
Select input:
enter amps: 60
Wouldnt a 1/4 hp motor and a 1/2 hp motor consume the same amount of power if the continuous load only required 1/8 hp. Amperage being based on load.
I know that 2 cims will be capable of more torque, I'm just wondering how noticeable it will be from the perspective of the driver.
Unread 21-01-2016, 23:18
Ether's Avatar
Rookie Year: 1969
Take a careful look at what I posted:
332+388 = 720 total watts consumed (one CIM)
447+273 = 720 total watts consumed (two CIMs)
They both consume the same power @ 12 volts @ 60 amps, but you get more output mechanical power and less waste heat with two CIMs.
So you don't need as many amps with the 2 CIMs to get the same output power as 1 CIM.
Unread 29-01-2016, 21:38
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
Rookie Year: 2011
MrRiedemanJACC will become famous soon enough
So if I may add to that and continue the idea with a 3 CIM gearbox and 60 amps total load on the the three motors, you use MCALC at 20 amps per CIM and get this:
oz-in=45.6, Nm=0.322, rpm=86.7, amps=20, watts out = 155.3, watts heat is 84.7 and eff% = 64.7
So I'm seeing the three CIMs each drawing 20 amps at 12 volts:
465.9 watts output mechanical power
254.1 watts waste heat
vs these two choices that Ether's calculations from before.
So not as much of a gain in efficiency improvement as I had hoped, but the package is still capable of much more.
Unread 22-01-2016, 11:47
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Probably not the right place to mention this but the thread on MCalc is actually closed.
In your MCalc32 equation sheet you say power_out = speed * torque. Given your Speed (2975) and the torque (1.066) I'm confused how you get 332.2 W out.
Edit: admittedly the only reason I noticed this was I don't have a windows machine and liked the concept of MCalc so started a Go version. (I also needed to learn Go for a project at work and this seemed like a simple program)
Unread 22-01-2016, 13:29
Ether's Avatar
Rookie Year: 1969
Convert everything to SI units to do the computations.
Convert 2975 rpm to 2975/60*2pi = 311.5 radians per second
311.5 rad/sec * 1.066 Nm = 332 Nm/sec = 332 joules/sec = 332 watts
Unread 22-01-2016, 13:31
Data Nerd
FRC #0079
Rookie Year: 2000
Ah, that's the part I was missing. Thank You. Now I'm only off by ~0.01 which I mostly attribute to using the motors.vex.com numbers which might be different.
Unread 22-01-2016, 13:35
Ether's Avatar
Rookie Year: 1969
I didn't close it. That happened a while back when the server crashed or got updated or re-hosted or something. I'll ask Brandon to re-open it.
  #15   Spotlight this post!
Unread 21-01-2016, 23:19
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We had 2 added 2 more today. Only problem is we were only able to get one screw in each Cim. We will try more probably making a tool to get in there but, we sadly have run a drive train an entire season using 1 screw per Cim and can verify it works.
