Go to Post "The robot is horribly overweight. We need to delete some code" - Dumper FTW 435 [more]
Unread 21-01-2016, 16:34
C.Lesco's Avatar
C.Lesco C.Lesco is offline
Engineering Captain, Driver
FRC #5870 (League of Logic)
Team Role: Leadership
Rookie Year: 2014
C.Lesco will become famous soon enough
Bumper numbers font
My team cant find the restriction for the bumper number fonts but we want something kindof crazy. Graffiti font is a popualr opinion. What are the restrictions for the numbers?
Unread 21-01-2016, 16:37
Abhishek R Abhishek R is offline
Rookie Year: 2012
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
Re: Bumper numbers font
You can find them in the robot section of the game manual, which can be found on FIRST'S website. I would post them here but I don't currently have access to it.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 21-01-2016, 16:42
Logan Byers Logan Byers is offline
Roaming Mentor & Referee
no team (Team Indiana)
Logan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud of
R28:
Originally Posted by FRC Manual
Team numbers must be displayed and positioned on the BUMPERS such that an observer walking around the perimeter of the ROBOT can unambiguously tell the Team’s number from any point of view and meet the following additional criteria:
A. consist of numerals at least 4 in. high, at least ½ in. in stroke width, and be either white in color or outlined in white
B. must not wrap around sharp corners (less than 160 degrees) of the FRAME PERIMETER
Unread 21-01-2016, 17:28
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
And while it's not a formal rules requirement, make sure that whatever you use can't be mistaken for a different number. Here are some suggestions towards that:
  • All of your openings and space between the digits should also be at as wide as the stroke width (or nearly so), so that a 5 is not read as a 6 or a 3, 5, 6, or 9 as an 8.
  • Include an opening in your 4 and a curved tail on your 9 to keep them from being mistaken for each other.
  • If you have a top serif on your 1, make it not much bigger than the stroke width, and that the top bar on your 7 is well over twice the stroke width, so they can't be confused.
Unread 21-01-2016, 17:49
MrRoboSteve MrRoboSteve is offline
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Only thing I'll add is to make sure they're readable from 30' away.
It's probably most confusing when we're on the same alliance as 3018.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 21-01-2016, 18:20
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
For a general purpose bumper font that works well on 8" bumper sections extended to the adjacent corner which allows for 11 1/4", see here:
http://fontstruct.com/fontstructions...604195/frc2530
This satisfied the 2012 rules and I think those rules were relaxed a bit.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 21-01-2016, 18:22
Be careful with 'Crazy' Readability from a distance is key for scouts to know who you are. Make sure crazy is readable. You are also at risk for inspection issues if you get too crazy for the same reasons.
John Vriezen
Unread 21-01-2016, 18:58
Robopromo's Avatar
Robopromo Robopromo is offline
FRC #2474
Robopromo is a glorious beacon of lightRobopromo is a glorious beacon of lightRobopromo is a glorious beacon of lightRobopromo is a glorious beacon of lightRobopromo is a glorious beacon of light
Looks like people here already did a good job of covering the rules, but when you figure out what font you want to do you can send the image to us at robopromo.com to have them professionally cut in our iron-on vinyl.
Here's a link for more info on our website:
http://www.robopromo.com/product_p/rp-2014.htm
