Go to Post This game is all about dealing with the unexpected and making changes on the fly. - Greg Hainsworth [more]
Unread 22-01-2016, 11:21
Robodragons4630 Robodragons4630 is offline
CHS Robodragons Programming
AKA: Noah Jarnigan
FRC #4630 (Robodragons)
Rookie Year: 2014
Robodragons4630 is an unknown quantity at this point
Toggling speed
I am trying to think of a way to toggle speed. What I am looking to do is make it so that I can choose a speed and then from that I have 5 seconds to move the joystick. While I am moving the joystick the case structure cant just go false. When the joystick isn't moving the case will be false and you have 5 seconds to move the joystick again before it goes false and you have to choose a speed again. I have a picture attached that shows my current vi.
http://i.imgur.com/y0bN7zo.png
Unread 22-01-2016, 11:40
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Rookie Year: 2010
adciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to all
Re: Toggling speed
Let me see if I have this correct
You want to set a speed.
If 5 seconds elapses, you want it to stop.
If the joystick is touched, you want it to reset the 5 second counter.
Ok, this uses the milli-second timer.
State 1: Speed Pass Through - When button is pressed, go to State 2 and maintain the speed setting (use a feedback node or shift register).
State 2: Have a 5 second counter in this state. If the counter expires, goto State 1. If the joystick exceeds a certain value, reset the counter.
I think that does what you want.
Milisecond timer counter:
Read the value from the millisecond timer and save it in a feedback node. Compare this to the present value of the millisecond timer. If the difference is greater than or equal to 5000, set the output to true. The reset button saves the current value of the timer to the feedback node.
Timer Embedded should do the trick I think
https://github.com/allancass/836-Lib...umatics/Common
Originally Posted by texarkana View Post
I would not want the task of devising a system that 50,000 very smart people try to outwit.
