Go to Post Where's the easy button on this thing... - Akash Rastogi [more]
Unread 22-01-2016, 12:28
noahl98 noahl98 is offline
FRC #1350
noahl98 is an unknown quantity at this point
USB Camera giving Invalid Image error
My team has been trying to set up camera feedback through the dashboard using Java. I have added the sample code from the Simple Vision example in eclipse.
When I deploy the code to the rio and start up the driver station I get this error.
Code:
Error when getting image from the camera: invalid image at pos 56403 (0) at edu.wpi.first.wpilibj.CameraServer.capture(CameraServer.java:222)
edu.wpi.first.wpilibj.CameraServer$2.run(CameraServer.java:192)
java.lang.Thread.run(Thread.java:745)
This error keeps spamming the log until I disconnect from the rio.
We are using a Logitech C170 web cam. I know that this camera hasn't officially been tested but it was the only one we had access to. Does this error mean that this camera isn't compatible?
Unread 29-01-2016, 23:45
Lennie Lennie is offline
FRC #5818
Lennie is an unknown quantity at this point
Re: USB Camera giving Invalid Image error
I used to mentor for Team 1717 and we only used the AXIS network cameras which worked fine in both C/C++ and Java. This year I'm mentoring a rookie team 5818 and we are trying to use the USB Microsoft Lifecam and are encountering this same error and the FPS is only 3-4 fps at 320x240. We noticed a delay of .1 seconds in the Java CameraServer which we reduced but still are unable to achieve a decent frame rate. Please help!
Unread 30-01-2016, 16:24
legts legts is offline
Autonomous Queen
FRC #2399 (The Fighting Unicorns)
Rookie Year: 2012
legts is an unknown quantity at this point
My team used the same camera last year. Our camera code is here: https://github.com/frc2399/2015-code...bot/Robot.java
It might be useful to look at it, let me know if you have questions!
Programming Captain on team 2399 for the 2016 season.
Programmer on team 2399 The Fighting Unicorns since 2014!
Engineering Inspiration Award GPR 2015
Semi-finalist Buckeye 2015 (thanks 4269 and 1987!)
