Go to Post Changing the world starts with changing yourself. - Jeremy_Mc [more]
Unread 22-01-2016, 15:40
itwasntme455 itwasntme455 is offline
AKA: Brandon
FRC #4791 (Pandroids)
Rookie Year: 2013
itwasntme455 is an unknown quantity at this point
New router setup
How do you configure the new router? Can't get ours to work.
Unread 22-01-2016, 15:49
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: New router setup
I would try to follow the steps on the wpilib screensteps site.
If that does not work please reply where you are having trouble.
Unread 25-01-2016, 15:19
DrWaSaBi's Avatar
DrWaSaBi DrWaSaBi is offline
FRC #1711 (The RAPTORS)
Rookie Year: 2015
DrWaSaBi is an unknown quantity at this point
yes. the screensteps are helpful.
Also, if you got your radio as KOP. you do not have to flash the firmware. They needed to put that note in the screensteps a bit higher in the instructions list.
And another thing, make sure you have administrative rights on the computer you are trying to run the radio config tool on. you can also right click on the program and select "Run as Administrator"
Good luck. Let us know how it goes.
Russ
Mentor FRC Team 177 The Raptors
TC Central High School
Traverse City Michigan, USA
Unread 25-01-2016, 15:47
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
http://www.chiefdelphi.com/forums/sh...44&postcount=4
http://www.chiefdelphi.com/forums/sh...d.php?t=142414
