Go to Post Quitting FIRST was so hard that I felt like I needed a 12 steps program to help me through it. - Ken Leung [more]
Unread 22-01-2016, 16:26
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
Team Update 4 (2016)
link
Silver means removed
Drawings
■ GE-16170_REV_A: Mounting hole dimension added, 1.0 0
■ GE-16080: Updated to incorporate GE-16081_REV_A
■ GE-16081_REV_A:
■ Width: 4.50 5.25 (width references also changed; the 4.50 dimension was derived from two other dimensions, while the
5.25 dimension is specifically marked)
■ Height dimension reference changed from top of flange to bottom of flange
■ Material: 5 Guage Aluminum Sheet, .1819 thick Steel Sheet, .125” Thick
■ TE-16080_REV_B – Updated to incorporate addition of TE-16080-05, including location adjustment
■ TE-16080-05: new part
Section 2.2.2 OUTER WORKS
■ The Rock Wall is a steel block that is 4 ft. 2 in. wide, 4 -1/2 5-¼ in. deep, and 4 -1/2 4-5/8 in. tall.
(For more information on the depth change, see yesterday’s blog. The height correction is to make the manual match the original, and current, drawing.
The height of the Rock Wall has not changed from the originally published drawing.)
Section 4.8 Motors & Actuators
■ Reformatted for clarity: Hard drive motors or fans that are: included in any Kickoff Kit, distributed via FIRST Choice, part of a legal
motor controller (including manufacturer provided accessories), or part of a legal COTS computing device
Section 5.5.10
■ The specific DEFENSES used during each MATCH are selected by a combination of the audience and the ALLIANCES. One (1)
DEFENSE from each of the four (4) DEFENSE groups, A, B, C, and D are on the FIELD each Qualification and Playoff MATCH.
During the Practice MATCHES, ALLIANCES select DEFENSES for positions 2 through 5 to fortify their opponent’s OUTER
WORKS and may select any four (4) DEFENSES from the four (4) groups. For example, each of the two (2) DEFENSES from
groups A and B. Also, OUTER WORKS DEFENSE positions 2 through 5 are selected by the opposing ALLIANCE, i.e. the Red
ALLIANCE selects the Blue ALLIANCE DEFENSES.
This provides each ALLIANCE with a predictable set of DEFENSES on which to practice.
During the Qualification MATCHES, ALLIANCES select DEFENSES to fortify their own OUTER WORKS (the OUTER WORKS closest to their TOWER).
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 22-01-2016, 17:28
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Rookie Year: 2010
Tam Update 4 (2016)
https://firstfrc.blob.core.windows.n...Updates/04.pdf
