Go to Post When your team becomes ubiquitous with the phrase "Always a bridesmaid, never the bride" - Peyton Yeung [more]
Unread 22-01-2016, 16:31
Heber Hooper's Avatar
Heber Hooper Heber Hooper is offline
Rocktaπ Inkling
AKA: Heber Hooper
FRC #6051 (Rocktaπ)
Rookie Year: 2016
Heber Hooper is an unknown quantity at this point
Exclamation Steel as a material
Is steel a recommended material for extentions of base kit?
Unread 22-01-2016, 16:36
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
Re: Steel as a material
If it works well and you can afford the weight (or need it to be a certain strength while remaining thin), then it's a fine material. It would be surprising if you couldn't solve the same problem with aluminum with less weight.
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 22-01-2016, 16:38
Connor McBride's Avatar
Connor McBride Connor McBride is offline
I live my life 2:30 at a time!
FRC #0166 (Chop Shop)
Rookie Year: 2013
Connor McBride will become famous soon enough
I recommend that if you use steel anywhere on your robot, use a small amount. You'll hit your 120 pound weight limit pretty quickly.
FRC 166 2013-2016 (student) 2016-present (junior mentor)
NHTI VEX U 2016-present (treasurer)
Youtube Channel Team Page Facebook Page
Unread 22-01-2016, 16:40
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Steel is very useful stuff. I prefer fasteners made of steel to those made of any other material. Motor cores should also be made of steel.
Aluminum is better for large, thick parts.
Richard Wallace
since 2003
Unread 22-01-2016, 16:41
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
Rookie Year: 2011
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
You'll have to be more specific. What do you mean by "extentions of base kit" ? Do you want an arm to extend outside your robot or make your kit bot frame larger or something else? Also "steel" comes in many alloys and tempers. I wouldn't buy a plate of tool steel to make my kit bot larger.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 22-01-2016, 16:47
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
Team Role: Mechanical
Rookie Year: 2011
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Almost all metal for FRC is usually aluminum of some sort. However, there are some applications where sometimes steel is preferred, notably in high torque gearboxes, shafts, keys, chain, and shifting mechanisms, although there are people who have accomplished this with aluminum as well. Also, many common fasteners are zinc-plated steel (or some other type of steel), so unless you want to specially source your fasteners, you'll probably use a lot of steel on nuts-and-bolts stuff.
There are some teams who have, often due to unavailability of other metals, built most of their robots with steel. Theoretically, both aluminum and steel can be used to make a great robot, it's just a matter of knowing how to use each material properly and in what situations. That being said, in practice, most often aluminum will be your best bet, especially with large robot parts (because steel is HEAVY), but this sometimes a flexible rule.
EDIT: What Mr. Wallace said about motors applies as well. You won't find many motors in FRC made of aluminum. Additionally, there are many types of both steel and aluminum, so selecting specific alloys and tempers can be important in addition to the steel vs aluminum debate.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 22-01-2016, 17:23
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We have used steel in very high Stress applications but it all comes down to weight. Also watch what alloy of aluminum you are using is that will play a role.
Unread 22-01-2016, 17:24
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Rookie Year: 1999
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
If you DO plan on using steel as structure, I would recommend keeping close tabs on weight as you build. (I recommend keeping close tabs no matter what, but more-so if you use steel) I remember a rookie team one year coming with a robot with a large steel superstructure that weighed in on practice day at around 300 lbs.
Unread 22-01-2016, 17:42
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
It's all in the design. Aluminum isn't as much lighter than steel as you might think. It's only 30% the density, but it's (generally) only 50% as strong, so you can afford to use smaller pieces with steel. The ratio of strength to density is called "specific strength". For instance, a 0.75" x 0.75" x 0.065" (thin) wall tube is roughly as strong, a little less stiff, and only about 30% heavier than a 1" x 1" x 0.095" wall 6063 aluminum tube.
Welding (most grades of) aluminum takes away half of its strength, whereas mild steel stays relatively constant, so the steel welded frame would end up slightly stronger. Plus any hack with a mig welder could weld steel for you, compared to aluminum where you need a TIG welder and a decent amount of experience. Steel is a heck of a lot cheaper than aluminum too! These are good reasons to give (thin wall) steel a careful look.
Unread 22-01-2016, 20:37
Kevin Sevcik's Avatar
Kevin Sevcik Kevin Sevcik is online now
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
My boss has a similar opinion when he was mentoring a team. He loved teaching the students how to weld up their frames. He was also mildly surprised that they were always very close to over weight. My primary arguments against him were that steel is a fair bit harder to cut and drill, and its difficult to get sections with walls thin enough to be comparable to aluminum. Getting something equivalent to 1x1x1/16 aluminum is not easy. And we've used smaller than that for lightly loaded structures before.
Unread 22-01-2016, 20:55
MrBasse MrBasse is online now
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Our lightest robots ever have had full steel superstructure built from 1/2 inch square steel tube. In 2011 we were ~85 lbs. and in 2013 we were right around 105 lbs.
We found that with a steel frame we used so much less material for the same strength.
Another benefit is when you hit something wrong, you just bend it back. Aluminium sure doesn't play as nice in that regard.
We use aluminum alot now simply because so many nice COTS items interface with common aluminum extrusions.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 22-01-2016, 21:51
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Another feature of steel is that lots of folks can weld it, even me! and I have little skill.
We have made two robots with steel frames. As mentioned, you want to use relatively thin steel...16 gauge square tubing is good, and easy to find. But also as mentioned, we don't know what it is you're trying to make, exactly. Sketches are very helpful when asking questions like this.
btw, most cars have been made mostly of steel for about a century. It works.
Unread 22-01-2016, 23:07
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
Rookie Year: 2011
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Just like everyone else has said, aluminum is the preferred material for the vast majority of FRC teams, because it's much lighter than steel and very easily accessible. Although steel is MUCH easier to weld, aluminum is easier to cut, drill, etc, and pretty much any FRC product you get off-the-shelf will be aluminum.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
