Go to Post Don't forget Morgan Freeman will be at champs. Maybe he and Will are gonna freestyle it! - Nuttyman54 [more]
Unread 22-01-2016, 20:31
Andrew Schreiber Andrew Schreiber is offline
Joining the 900 Meme Team
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Simple Motor Calculator for Linux/OS X
Several years ago Ether released a Simple Motor Calculator (http://www.chiefdelphi.com/media/papers/2432) that lets you specify a motor and some parameters and it will tell you what the motor is doing at that point (ex specify the current a motor is running at and it will tell you torque, speed, efficiency) The issue is it was only for Windows and a handful of folks don't run Windows... so I took the equations he provided and put them in a simple command line application.
https://github.com/schreiaj/motorcalc-uni Here is the code, or for those of you who just want to try it here's the releases page https://github.com/schreiaj/motorcalc-uni/releases please try it out and let me know if I can make it more useful to you.
Currently supports CIM, 2xCIM, 3xCIM , Bag, AM775, 775pro, and AM9015 and specifying amps or torque. I'm aiming to add in rpm soon.
Hope you find it useful.
