Go to Post Take what you have learned, build on it and share it. Others will do the same. Enjoy the journey. - Bertman [more]
Unread 23-01-2016, 10:51
schleprock's Avatar
schleprock schleprock is offline
Code Jockey
FRC #4905 (AndromedaOne)
Rookie Year: 2014
schleprock is an unknown quantity at this point
Question can the 2015 dlink be reprogrammed for 2016
i understand that we're using a new router for 2016. but i would like to use the dlink from last year on a backup robot. does anyone know if the dlink can be reprogrammed to work with the 2016 software?
Unread 23-01-2016, 11:01
billbo911's Avatar
billbo911 billbo911 is online now
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: can the 2015 dlink be reprogrammed for 2016
R57 One (1) OpenMesh Wireless Bridge (P/N: OM5P-AN), that has been configured with the appropriate
encryption key for your team number at each event, is the only permitted device for communicating
to and from the ROBOT during the MATCH.
And from the Blue Box right after this rule.
The D-Link DAP1522 radio distributed from 2011-2015 is not legal for
2016 FIRST Robotics Competition Competition.
As long as you use it on a practice robot at your shop, it "should work". But that is just my opinion.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 23-01-2016, 16:44
schleprock's Avatar
Code Jockey
Rookie Year: 2014
Question Re: can the 2015 dlink be reprogrammed for 2016
thanks for the reply. i was already aware of the requirement for the new radio at the competition. we want to use the dlink on our practice robot (not the one we use in competition) and was wondering if it can be reprogrammed to work with the 2016 software update. right now we have it programmed for last year's competition and it does not work with a roborio that has been updated to 1016 software.
so my question still stands, can the dlink be reprogrammed to work with the 2016 software?
Unread 23-01-2016, 16:58
Starwarsguy2's Avatar
Starwarsguy2 Starwarsguy2 is offline
Too many robots, not enough time
AKA: Jake Morris
FRC #0316 (LuNaTeCs)
Rookie Year: 2015
Starwarsguy2 is a splendid one to beholdStarwarsguy2 is a splendid one to beholdStarwarsguy2 is a splendid one to beholdStarwarsguy2 is a splendid one to beholdStarwarsguy2 is a splendid one to beholdStarwarsguy2 is a splendid one to beholdStarwarsguy2 is a splendid one to behold
We have been using the 2015 router with a 2016 RoboRio. I believe that we re-flashed the router using the new bridge configuration tool. I'm not sure though, I can get more information on Tuesday. Good luck.
Too much robots is still not enough.
Unread 23-01-2016, 20:03
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
The 2016 FRC Radio Configuration tool has a setting to program the older DLink for use with this year's robot.
Follow the directions in programming radio for home use in screensteps.
Unread 25-01-2016, 12:04
Robomarfa Robomarfa is offline
FRC #5771 (Robohorns)
Team Role: Teacher
Rookie Year: 2015
Robomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to allRobomarfa is a name known to all
Yes. The old Dlink works with the new 2016 environment. We are using just that for our software development platform.
Unread 25-01-2016, 12:38
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
For home/shop use only, can you not just use any router that can provide DHCP to your RoboRio and your driver station laptop?
Unread 25-01-2016, 12:44
Just Itinerant
Yes, you can use any router you want to at home.
It's just a router/AP, nothing special.
You don't even have to change the router IP to a 0. address, it's just usually convenient to do so.
DHCP serving 10.te.am.20 and higher addresses (or similar) is all that's necessary.
I use all my old outdated home AP/router/DSL/whatever to run old robots.
Unread 24-02-2016, 02:45
cartwrig cartwrig is offline
FRC #1720
cartwrig is an unknown quantity at this point
What happened to Team 358's website?
We had bookmarked lots of good info, back during Fall 2016; and, then every time we wanted to refer to some info on your website for the past 6 weeks it was gone....the whole site, in fact.
Thanks,
- Rob
Unread 24-02-2016, 08:24
Just Itinerant
About 2 weeks into build season our hosting service couldn't handle it any longer, so we are switching to a new service.
But with how busy build season is I just haven't had time to redirect the nameservers.
It'll get done soon, after I've had a bit of a rest.
The site is mostly available via the Wayback Machine
