Go to Post Ya know...sometimes, design specs get changed at the last second. Or the market changes while you weren't watching. It Happens. - DonRotolo [more]
Unread 12-08-2002, 02:57
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Chiaphua Drivetrains
We tried a dual motor gearbox this past year using drill motors and gearboxes on high speed and Chiaphua motors mated with their cluster gears. There was a 32P 64T common spur gear mounted on a central shaft spun by the small part of the cluster gear and a 16T pinion on the drill output shaft. This central shaft also had a sprocket mounted on it that conected by chain to the sprockets on the wheel axles. This whole thing was great and really fast and powerful, I mean really. Unfortunately it only lasted a few runs before self destructing. Gears stripped like crazy.
I'm interested in knowing how teams that use the Chiaphuas (alone or with other motors) get the power out of the motor and into the wheels. Sprockets, Cluster gear, other gears, custom shafts, what? What I'd really like to see or hear about are the designs that don't need 30 CNC-ed parts but if you've got a kickin' drive train feel free to brag a little.
Show me some Chia drivetrains!!!!!!
Unread 12-08-2002, 07:59
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Ian W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to all
Send a message via AIM to Ian W.
well, michael designed us a multi motor drive train, and it's still kicking (well, if the robot was put back together). maybe i can get a pic of it later today. i know that we had a small gear on the chiphua motor shaft, and then a really big one on the drill motor. they don't spin at exactly the same speed, but it's made so that the chiphua will just use it's power to time it correctly. then, we used the drill motor transmission, set to high (i think), and used the shaft on that to drive wheels/treads. i know that's not an extremely detailed explination, but i'm a programmer .
AIM --> Woloi
Email --> ian@woloschin.com
Unread 12-08-2002, 13:14
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
Our drivetrain was just a single-motor unit, but it worked remarkably well, and we never had a single problem with it. We used a combination of free-spinning gears and locked-down gears with a shifting collar to achieve a 5:1 and 10:1 reduction, followed by additional sprocket reduction. I've attached a picture, but if you want more info, post a question, or PM me.
All the gears were purchased through gear vendors with the exception of the center splined gears. Those are part of a driveshaft gear from a car welded to a normal gear. The collar is made from the mating piece to the splined gear, and is shifted pneumatically.
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
Unread 12-08-2002, 13:34
Team Role: Teacher
Thanks for the pic. It's pretty cool. I still don't get though exactly what moves to make it shift?
Unread 12-08-2002, 14:00
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
I'd guess it's the big block in the center that moves. The drive shaft has a splined shaft that is currently hidden by the block. The block also contains a splined coupling. When the block moves to the right, the coupling connects the spline to the gear train on the right. The left side freewheels on the output shaft. When the block goes to the left, the left is driven and the right freewheels.
As I recall, the TechnoKats use a similar concept with a different coupling mechanism. Kingman's was also similar.
Actuation is done by the pnuematic cylinder on the left.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 12-08-2002, 18:08
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Rookie Year: 2000
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
TechnoKats
Here is the drivetrain we had that used the chiaphuas.....
White Paper by Andy Baker-->> 6 Motor Drive Assembly w/ Pneumatic Shifting of 4:1 Gearbox
The contents include these pages:
Background
Overview
Assembly Pictures
Fabrication Tips
Assembly Tips
Performance & Specifications
Bill of Material
Assembly Prints (4)
Part Prints (27)
Below is a picture of the gearbox.
Purdue Alumni
Cummins, Inc.
Unread 13-08-2002, 10:31
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Rookie Year: 2000
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
All i have to say is the "CCT" or Crazy Chicken Transmission! I saw it at GLR, and it was awsome, but i don't know if they hooked it up to chipewa motors, though...
That rug really tied the room together...
Unread 13-08-2002, 10:56
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
In the White Papers section is Team 716's dual motor gearbox. It uses the Chiapuas and the drill motors. It also has a modification to the TechnoCat's drill motor mount.
Some machining required but CNC not needed.
We never broke anything except the stock final output of the drill transmission - only because we didn't follow Dr. Joe's advice and replace it. We will replace it next year if we still have the drill motors.
Unread 13-08-2002, 11:18
El Jefe de 148
Yep, that's exactly how it works. Probably a more clear and concise explanation than I would have given, too.
Jeff Waegelin
Unread 13-08-2002, 12:25
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Erm, that's it, pretty much.
We coupled the Chiaphua and the Drills (in high) together. Gear shifting was done by the 'antitransmission,' so the whole mechanism was really simple. I don't have any good pictures, though.
If I recall correctly, the ratio from Chiaphua to Drill output was 1:5.33 or so (or, maybe 5.33:1...I was on vacation, so my brain is off). . . it was close enough for our needs.
The real key to the awesomeness embedded in the drivetrain was the antitransmission and belting.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Matching Drill and Chiaphua sanddrag Motors 12 17-01-2003 11:23
Coupling the Chiaphua & a variable Drill output Jeff Sharpe Motors 9 13-01-2003 20:21
Chiaphua Spec Sheet Joe Johnson Motors 12 09-01-2003 16:01
drilling that chiaphua gear ahecht Motors 8 06-02-2002 01:23
Chiaphua gearing (Chippy and Bosch) honky Motors 3 31-01-2002 10:28
