Go to Post We're thinking of using static electricity to pick up the tubes. The programmers are trying to figure out how to make the robot shuffle it's feet on the carpet. - Tom Ore [more]
Unread 23-01-2016, 13:12
jdf001 jdf001 is offline
FRC #4296
jdf001 is an unknown quantity at this point
Chain or gear drive?
Hello! We're wondering about drive trains. So far all of our drive trains have been driven off of chain and sprocket. This year we were thinking about making a drive train using all gears to transfer power from the gearbox to the wheels. I was wondering if any of the teams that have tried this in the past have any thoughts on the pros and cons. Thanks!
Unread 23-01-2016, 13:17
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: Chain or gear drive?
It is getting kind of late to make that decision. Chain is cheaper and easier to do. I have heard some arguments for gear drives but have yet to really hear one that I like (other than reliability, which is true for any correctly made drivetrain).
At this point you may want to opt for KOP chassis just to save time.
<Now accepting CAD requests and commissions>
Unread 23-01-2016, 13:19
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
Pros: Strength and better long term reliability, No chance of belt or chain breaking or becoming misaligned.
Cons: Cost is vastly higher I would imagine, Weight would for sure be higher, and Gear drives need to be constantly lubricated. Gear drives can also be very loud. I'm also pretty sure that creating the plates that the line of gears would have to mount to, depending on how you did it, would have to be precision machined.
Most of my FTC drives were all gear driven, but I would imagine FRC gear drives would be very much more expensive. My FRC experience is limited to Belt & Chain so you'll have to wait for someone with more expertise to come alone.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 23-01-2016, 21:11
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
I haven't used it so I can't recommend it, but there is a COTS all-gear 6 wheel drive available from AndyMark. As noted above, it's heavy and expensive. If you want to go down this road, you may want to use this or just examine it for ideas/inspiration.
Edit: We have used nanodrive, just not the all-gear. Kind of strange to assemble, and the gearbox is not fully enclosed, but our air cannon (which is quite a bit heavier than FRC legal) runs well on it.
Unread 24-01-2016, 22:00
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Rookie Year: 2010
adciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to alladciv is a name known to all
Don't forget about belt drive trains. You have to make sure you order the correct sizing, but they have been pretty reliable for us.
Originally Posted by texarkana View Post
I would not want the task of devising a system that 50,000 very smart people try to outwit.
Unread 24-01-2016, 22:52
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Rookie Year: 2013
Won't the $400 upper limit prevent a team from using that chassis? Did they remove that rule this year?
Unread 24-01-2016, 22:56
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
That's actually a really good question. I wonder if this chassis isn't intended for competition use, but rather as an off season learning tool?
Unread 24-01-2016, 23:31
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
Does it count if most or all of the components are individually purchasable? You could (extremely easily) purchase each gear and wheel and bearing on its own and come up with the same product. Does that mean you have to?
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Unread 24-01-2016, 23:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
REad the rules, you might find that if the individual components can be used in different configurations, and you buy several components that work for your configuration, for under 400 each, it's ok. But if the components can only be assembled into one configuration, then you have to keep the price of the whole thing under 400.
From the web page, it looks like it's a one shot deal, and it costs over 400, so it would be illegal. But that's just my interpretation.
Unread 25-01-2016, 09:52
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
we started using belt drive a few years ago and we will NEVER go back to chain.
with the correct spacing you never need a tensioner. Set it and forget it.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 08-02-2016, 08:53
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
I'm curious what you're gearing your belt-drive bot to, and what kind of belts/pulleys. We just switched *to* chain after several years of belts, because in very-high-torque pushing matches our 15mm HTD belts would jump even with laser-cut center-to-center mounting plates (and then even with delrin tensioners).
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 26-01-2016, 20:39
FRC Warrior FRC Warrior is offline
FRC #4169
FRC Warrior is an unknown quantity at this point
It's legal. Each of the individual components are <$400. It literally has a list of components that you can buy individually. You could put together those components in several different ways. How many different ways can you use a CIM motor? Or a washer?
Unread 26-01-2016, 20:56
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
We have done gear drives in the past and will also be doing it this year. We love the reliability. We haven't had a single failure with these drives.
Yes it's expensive, building up an inventory of gears and bearings over time has significantly reduced that cost for us but initial cost is high. The Vexpro AI gears are extremely durable and usable year after year.
Lubrication is no more of a problem than any other gearbox. A tiny bit of grease before every comp is all we have ever done.
Heavy? Maybe, maybe not. #35 chain is heavy, #25 and belts would be lighter but we haven't had any troubles with weight and what ever extra weight there may be is right where you want it.
Yes, gear spacing is critical. Some form of CNC machining should be used. We have a great sponsor in Waterjet Cutting of Indiana.
Like anything new, I would recommend off season testing for something you are trying for the first time but if you have confident CAD skills and a way of machining it, go for it.
Unread 30-01-2016, 23:25
FRC #4296
We're going for it, the gear trains certainly are a beauty.
  #15   Spotlight this post!
Unread 07-02-2016, 22:11
arc25565 arc25565 is offline
FRC #1482 (Ghosts)
Rookie Year: 2015
arc25565 is an unknown quantity at this point
benefits of chain: Light, cheap, relatively easy to assemble
Benefits of gears: Reliable, quick change of direction, little maintance
