Go to Post And who knows, maybe one day you'll prove the impossible possible! - MissInformation [more]
Unread 24-01-2016, 18:44
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
Re: 775 Pro Coupling
Originally Posted by AustinSchuh View Post
To echo what RC is saying here, we've been doing this for years, with RS550's, 775's, and are planning on doing it with 775 Pro's this year. RC added that part to his inventory based on feedback from us. We press it on to the 775 with the short flange 0.020" from the motor face to reduce the cantilever. We've never had an issue. (Last year's bot had 7 per robot 775's with pinions pressed on as described. We had 0 failures.) With bearings in the new 775 Pro, this should be even less of an issue.
Do you guys have a source for other size gt2 pulleys? I can buy the pinion from WCP, but where do get your others from? (I was hoping mcmaster would sell them).
Also based on it's size it looks like gt2 is close to MXL, any experience in the difference between the two?
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 25-01-2016, 09:30
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Originally Posted by R.C. View Post
If your looking to do that, then its the same as buying the GT2 pulley here:
http://www.wcproducts.net/gt2-timing-pulleys-belts
Can you point me to a C-C distance calculator that works with the GT2 3mm 12 tooth pinions that WCP sells? The one at SDP-SI only goes down to 16 tooth.
I would like to use this pinion to drive a 44 or 45 tooth pulley from SDP-SI. Will exact C-C set up work, or will I need a side tension system to keep six teeth of the pinion engaged to the belt?
Richard Wallace
since 2003
Unread 25-01-2016, 11:30
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
Rookie Year: 1996
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
In the past I've just emulated the Versa strategy.
I used the VexPro "c" collar from the Versa and just reamed the pulley to 8mm then applied clamping force from a set screw.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 25-01-2016, 22:22
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
It's actually pretty easy to do in Solidworks. Draw out the belt as a bunch of arcs with a diameter of (3mm * num_teeth / pi) and straight lines. Use the Path Dimension feature (It's in the drop-down menu in the sketch menu under the Smart Dimension tool) and select all the lines. Set the path length to (3mm * num_belt_teeth). Done!
For short belt runs, you might want to remove a couple thou. We tend to just run exact c-c and move on. For longer ones or more critical ones, we add a tensioner.
Unread 25-01-2016, 22:39
Rookie Year: 1996
Thanks for the CAD trick -- I will get one of the students to try it!
An equivalent old-school method uses pitch diameter circles and tangent lines connecting them to calculate the wrap angle on each pulley, and then get center distance from the resulting two arcs and two lines. One such calculator can be found here: http://www.gizmology.net/pulleysbelts.htm
Using that one I got 4.773 inch C-C for a 110 tooth belt connecting a 12 tooth pinion to a 45 tooth pulley at 3mm tooth pitch. Will check that against the CAD result before we cut holes in metal. Measure twice ...
Richard Wallace
since 2003
Unread 26-01-2016, 01:48
Rookie Year: 1999
Our favorite reduction is a 56 : 12 with a 67 tooth belt. I think we might have had 6 of them last year. I love GT2 since there is such a safety factor that it isn't a huge issue if you don't get everything else perfect. (6 teeth of engagement is 180 degrees. I try to target at least 120.)
Unread 25-01-2016, 23:56
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
You can change the type of pulley to "timing pulley stocks" to get down as low as 6t. You also have to go to Metric instead of Inch.
EDIT: I got the same result but with only 5 teeth in engagement.
<Now accepting CAD requests and commissions>
Unread 26-01-2016, 06:02
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
We were going to do that. It was all CADded and everything. Then I looked at the load rating of 3mm GT3 belts. They were only rated to 10000 RPM on the faster sprocket (unless I'm reading it wrong). So attaching it to the 775pro with a free speed of >18000 RPM scared me.
Unread 24-01-2016, 20:48
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
We were also concerned that 775 motors might not handle side loads well.
We've had good results using 3/8 hex shaft stock (217-3310) to fabricate 5mm bore press-fit shaft adapters for the 775pro. Here is our method: (lathe)
-- rough cut stock ~1 inch long using chop saw or band saw
-- face both ends to give 7/8 inch finished length and break edges
-- center drill
-- drill through #21 (0.159 inch dia)
-- drill about halfway through #9 (0.196 inch dia) <-- this step gives a press fit hole diameter for the 5 mm motor shaft
-- tap the smaller end 10-32
-- using arbor press, align squarely and press motor into large end of adapter
(Note: arbor press ram should only touch the back shaft, not the motor body)
A 3/8" hex bore gear on the adapted motor shaft drives a larger gear on a 1/2" hex output shaft. Both shafts are supported by bearings in a gearbox housing, which we make on a mill using 1x3 rectangular aluminum tube with 1/8 inch wall thickness. The output shaft bearings are installed flanges-in with a 1/8 inch plastic spacer between the gear and one bearing. The motor face mounts to one side of the tube* secured by two M4x10 button head screws, then a spacer and the shaft gear go on, and a 3/8" hex bearing (217-2735) goes in flange-out. A 10-32 x 0.5 inch button head screw and washer keep the bearing in.
Free current draw with this method is less than we saw testing with a Versaplanetary, and the gears are easier to keep lubed. It is also easier to integrate this gearbox into our shooter because the output shaft is also a shooter wheel axle, supported by another bearing on the opposite side. Another benefit is that we can select any of several gear ratios that use the same total number of teeth. That includes options smaller than 3:1, which is lowest ratio available using Versaplanetaries.
*Vent holes in the tube wall, aligned with those in the motor face, are highly recommended.
We did the same thing for one of our prototypes. Pressing a short section of 3/8" hex shaft onto the motor has worked great. We hex broached some timing pulleys and secured them with a shaft collar. Being able to quickly swap out pulleys or gears on the motor is really helpful. We used a 0.195" reamer for the hex shaft. This is a little on the tight side, but it goes.
