Go to Post Well our closest regional is a Hawaii, it's a bit hard for us to drive 8000km (5000 miles) across the pacific... - timytamy [more]
Unread 12-08-2002, 23:37
Ashley Weed Ashley Weed is offline
Rookie Year: 1995
Ashley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond reputeAshley Weed has a reputation beyond repute
Question motor mounting
I have no idea how to search the white papers, so I am posting in hopes that someone may know if there are any white papers on motor mounts?
Or, if you would like to share how your team mounts motors please do. Thanks in advance!
Unread 13-08-2002, 01:56
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
We mount the drill motors and gearboxes in their green cases. The green housings are then mounted to the chassis with 6-32 threaded rod using the holes in the housings. We mount chiaphuas using their mounting holes which I believe are 10-24 and put screws through a vertical 1/4 inch thick or so vertical aluminum piece or angle. I've seen some teams attatch motors with hose clamps but I'm unsure of the rigidity of this method.
Motor mounting isn't really difficult. Give it a try.
Unread 13-08-2002, 06:23
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Rookie Year: 1999
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
A good mount for the Bosch Motors with the transmission is in the Technocats shifting white paper (from a while ago, and in the newest one also) Battlebots also mount the transmission by making a mount that the tranny slides into and bolting into the clutch holes. I think the team that makes these is TeamDelta
We mounted all motors this year on the faceplate of the motor
Unread 13-08-2002, 11:31
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
We mount our drills with large U-bolts. The drills are left in the green plastic casing, and then we put the u-bolts over the open side and attach them to wood or a metal plate on the other side. We do the same thing with the Chiaphuas. It works well, and we've done it on at least 5 different robots with no problems.
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
Unread 13-08-2002, 18:09
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Rookie Year: 2000
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Motor Mounting...
If u go to the TechnoKats Website; then go under "Resources" you'll see PDF and DOC files for the 2 different mounts (they are both pretty similar) we made for the drill motors/fisher price motors....
Purdue Alumni
Cummins, Inc.
Unread 29-08-2002, 16:01
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
Re: motor mounting
is there even a way to search them (the white papers)?
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 29-08-2002, 16:19
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Re: Re: motor mounting
i don't believe there is, and as for mounting the bosch drill motors, we find that the green casings work very well if you cut a lot of them away to increase the air flow onto the motor itself, they get very hot sometimes
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 29-08-2002, 21:21
Jack's Avatar
AKA: Andrew Schenk
Re: Re: Re: motor mounting
thats a good idea. i know that our team sometimes needs to give the drill motors a break because they are too hot. we never thought of cutting away the case for better air flow
Unread 30-08-2002, 10:05
El Jefe de 148
Re: Re: Re: Re: motor mounting
Actually, we have, but probably not to the extent that Nataku suggested.
Jeff Waegelin
Unread 31-08-2002, 14:42
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Rookie Year: 2000
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
yea those clutch holes
how far apart are those holes???!!! i know how to mount them but how far??!!!
Badjokeguy
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
