Go to Post please take the time to kick me in the butt. - Andy Baker [more]
Unread 24-01-2016, 08:29
jreneew2's Avatar
jreneew2 jreneew2 is online now
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
Rookie Year: 2013
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Question Multiple timer objects / deleted timers
Just a quick question for people who know C++ better than me,
I am writing some code for mechanisms on our robot and am trying to have one command for controlling the shooter in teleop and auto modes. I have in OI.cpp:
Code:
buttonA->WhileHeld(new ShooterControl(1)); //forwards
With my undertanding, WhileHeld makes a new instance of the command each time the previous finishes.
and in ShooterControl.cpp
Code:
#include "ShooterControl.h"
ShooterControl::ShooterControl(float speed, float target)
	// Use Requires() here to declare subsystem dependencies
	// eg. Requires(chassis);
	Requires(Robot::shooterSubsystem.get());
	timer.reset(new Timer());
	timer->Reset();
	timer->Start();
	timeCurrent = 0;
	timeTarget = target;
	inputSpeed = speed;
	isDone = false;
// Called just before this Command runs the first time
void ShooterControl::Initialize()
// Called repeatedly when this Command is scheduled to run
void ShooterControl::Execute()
	timeCurrent = timer->Get();
	if(timeTarget == 0) { //if zero use in teleop mode
		Robot::shooterSubsystem->Shoot(1);
		isDone = true;
	else {
		if(timeCurrent >= timeTarget) {
			Robot::shooterSubsystem->Shoot(0);
			isDone = true;
		else {
			Robot::shooterSubsystem->Shoot(inputSpeed);
			isDone = false;
// Make this return true when this Command no longer needs to run execute()
bool ShooterControl::IsFinished()
	return isDone;
// Called once after isFinished returns true
void ShooterControl::End()
// Called when another command which requires one or more of the same
// subsystems is scheduled to run
void ShooterControl::Interrupted()
Would this code bog down memory because of the multiple instances of the Timer Object? When does a timer get deleted?
Thanks,
Drew
