Go to Post If you don't like physical play build a stronger robot. - Koko Ed [more]
Unread 01-24-2016, 10:26 AM
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant future
Robot preferences help
Hi
We're trying to get the robot preferences to work. We followed the example on the screen steps page (http://wpilib.screenstepslive.com/s/...martdashboard), but are confused with a number of things. We're doing command based programming in Java.
1) should this go in the robot init like in the example? Doesn't that mean you need to reboot the Rio every time you change the file?
2) we can't seem to get anything to show up in the preferences. The things that I have found in the forums are a couple of years old so I'm not sure if it's changed.
3) if we create a key in the preferences table that doesn't exist in the code does that have any impact?
4) we trying declaring the variables as public in our robot.java but while in other commands or subsystems it doesn't seem like we could use them. Is there something I'm missing there?
Thanks for any help!
Andrew
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Unread 01-24-2016, 01:03 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Robot preferences help
We typically read preferences either in disabled init or inline with where the data is used (based on how often we want to be able to updated it).
The code on screensteps doesn't put any data to the preferences, just reads existing data. You can either add the data using SmartDashboard, or put it in your code. Generally, if our robot code reads a value and it doesn't exist the code immediately puts a default value to preferences.
No.
You need to references them as Robot.value. Or you could just read the preferences in your command or subsystem.
Unread 01-24-2016, 03:49 PM
ahartnet's Avatar
Thanks for the suggestions! I like putting it into the disabledInit() function.
Still having some problems though.
Code:
	public static double speed;
	Preferences prefs;
        //Other stuff
    public void disabledInit(){
    	speed = prefs.getDouble("speed", .5);
And then later on in a different class
Code:
     value = Robot.speed;
However we're having issues where we're getting an unhandled exception for a null pointer in the disabledInit function, so the driver station is listing as "no robot code"
Any suggestions?
Unread 01-24-2016, 04:01 PM
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
Rookie Year: 2011
fovea1959 will become famous soon enough
in addition to declaring
Code:
Preferences prefs;
are you initializing the 'prefs' variable before using it?
Code:
prefs = Preferences.getInstance();
Usually a NPE (NullPointerException) is caused by using a variable before initializing it.
Unread 01-24-2016, 05:14 PM
ahartnet's Avatar
d'oh! That was at least part of the problem.
Still having some issues that might be related to the scope or static-ness of the variable. For some reason in order to acces it in a different class, the code wants us to make it static.
Code:
    	speed = prefs.getDouble("speed", 0.0);
	SmartDashboard.putNumber("Pref speed", speed);
Code:
	SmartDashboard.putNumber("Pref speed in different class", Robot.speed);
In smart dashboard we'll get
"Pref speed": # (this updates appropriately when we disable)
"Pref speed in different class": 0.0 (this stays at whatever we initially set it to no matter what this doesnt surprise me because it's declared as static).
Thanks for all the help so far.
Unread 01-24-2016, 05:42 PM
ahartnet's Avatar
Alright, I think we have it figured out enough for how we'll use it. I think the issue is that we were trying to send the value into a function in a command group for autonomous. When we try to just read it in our teleop mode, we don't have the same problem. It's weird, but I think we can work around it.
If anyone else has a similar issue, for our command based programming we did still have to declare are variable in Robot class as:
My suspicion is that it has to do with being used in a command group. When a new command group was made for our sendableChooser, it must poll what that variable is at that point in time. Then when that command group is called later, it must not look at if the variable has changed.
Thanks!
