Go to Post "Everything is possible. Just depends on how much it costs and how much physics you have to apply..." - Kimmeh [more]
Unread 24-01-2016, 11:11
Beaker's Avatar
Beaker Beaker is offline
624 Programming Alum
AKA: Justin K.
no team (No Team)
Rookie Year: 2013
Beaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to beholdBeaker is a splendid one to behold
Talon SRX Firmware 2.0 Problem Encountered
Yesterday when we were testing some motors on our offseason testbed, we decided that we wanted to update our Talon SRX motor controllers from v1.4 to v2.0. The update went fine, we connected to the roboRIO web interface and loaded the firmware located in C:\Users\Public\Public Documents\.
However, after we tried driving the bot, the drivetrain would either stay stationary, or only one side would move (it was not always the same side). At first we chalked this up to a programming error, but after disabling all the code that was not pertinent to the drivetrain, the behavior continued. I reverted to last night's code and even our Feed Forward Code that we developed in the offseason, both of which worked wonderfully the day prior, but to the same effect. Of course, we restarted all the things (LabVIEW, Computer, Robot), but that did not work either.
Only after reverting to v1.4, were we able to get the desired behavior from the testbed.
Is there something wrong with the way we updated the firmware, or is there a known issue with v2.0 that we missed?
Team 624 (Student) 2013-2016
BBQ FIRST Creator
Unread 24-01-2016, 11:37
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: Talon SRX Firmware 2.0 Problem Encountered
There are no known limitations upgrading from 1.4 to 2.0. You should probably send your code and explanation of your setup to support@crosstheroadelectronics.com
Unread 24-01-2016, 13:43
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
Team Role: Coach
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
Are you using CAN or PWM to drive the Talons? If you use CAN you may need to re-address them. Check the GUI on the RoboRio for proper device IDs. We've not upgraded ours yet but I know sometimes a f/w upgrade can wipe out configuration data.
Unread 24-01-2016, 13:50
ozrien's Avatar
Omar Zrien
AKA: Omar
A firmware update should not cause any settings to reset. See section 16.20 in the Talon SRX software reference manual.
Unread 24-01-2016, 16:04
Beaker's Avatar
AKA: Justin K.
no team (No Team)
Rookie Year: 2013
We are using CAN, but the Device IDs stayed the same. It was interesting, because there were no CAN errors when diagnosing the issue.
It didn't seem like the settings reset, everything stayed the same except for the firmware version.
BBQ FIRST Creator
Unread 24-01-2016, 16:26
system201 system201 is offline
FRC #0201
system201 is an unknown quantity at this point
Our Team Updated And Everything Went Nicely...
We Found Our Image Here
http://www.ctr-electronics.com/talon...ical_resources
Unread 24-01-2016, 17:01
sraque's Avatar
sraque sraque is offline
AKA: Steve Raque
FRC #2614 (MARS)
sraque is on a distinguished road
Are you using the standard Talon VI's or your custom ones? I know you had a folder of your own custom VI's in the code release.
Unread 24-01-2016, 23:01
ozrien's Avatar
Omar Zrien
AKA: Omar
Hey All,
Bringing this thread to a close: root-cause is the LabVIEW team project had forked implementations of some Talon-centric VIs, but not all. The VIs were forked for performance reasons. So updating to 2016 meant the application used some old (forked) VIs and some new VIs, effectively breaking Talon-use.
I generally recommend to teams to always use the stock Talon VIs - BUT, if you REALLY need to make changes to be successful, you should kit all related VIs so future RIO updates don't lead to a mixed bag of things.
Unread 25-01-2016, 07:54
pribusin's Avatar
Uber Alien
AKA: Mike 1
Team Role: Coach
Hey All,
What do you mean by 'forked VIs'? I'm not familiar with that term.
Unread 25-01-2016, 08:12
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
FRC #1684 (The Chimeras) (5460 Mentor)
Rookie Year: 2013
Arhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to beholdArhowk is a splendid one to behold
It meant that OP copied over the source code of the can talon.vi and edited It.
FRC Team 1684 - Head Programmer (2013-2016)
FRC Team 5460 - Programming Mentor (2015-2016)
FIRST in Michigan - Technical Crew (2015-continuing)
