Go to Post I propose, these forums are not a competition. There is no race to prove a point, to prove you are right, to prove you are wrong. - rees2001 [more]
  #16   Spotlight this post!
Unread 25-01-2016, 14:47
Cash4587's Avatar
Cash4587 Cash4587 is offline
Mentor
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Team Role: Coach
Rookie Year: 2013
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Re: pic: 57's frame is coming along
I would be careful using the plastic clamping bearing blocks we broke a few on the ri3d chassis going over the obstacles with speed.
  #17   Spotlight this post!
Unread 25-01-2016, 15:01
Team34Guy's Avatar
Team34Guy Team34Guy is offline
Controls/Programming Mentor
AKA: Chris Southard
FRC #0034 (Rockets Team 34)
Team34Guy is a jewel in the roughTeam34Guy is a jewel in the roughTeam34Guy is a jewel in the rough
Originally Posted by s_forbes View Post
Looks eerily similar to ours.
Ours as well....I had to take a second look. Realized that the idler wheels in the middle were different.
  #18   Spotlight this post!
Unread 25-01-2016, 15:33
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Cooper, that is a fascinating insight. Like I said, this isn't our actual chassis. We're using the aluminum VersaBlocks for the outside wheels on our chassis, but we're using a plastic bearing block for the middle wheel to get the 96 tooth spacing from two simple clamping gearboxes. I'll definitely have the students abuse the chassis a bit to see if we need to do something about the plastic block for the middle wheel. If it's too fragile, I'll have to mill down a versablock to get the same spacing.
  #19   Spotlight this post!
Unread 26-01-2016, 02:20
Cash4587's Avatar
Mentor
AKA: Cooper Cash
Team Role: Coach
Rookie Year: 2013
I think the block would be fine if it didn't take so much load from wheels being cantilevered. We had the issue on the outer wheels of a wcd and not so much the middle wheel because at that point the middle wheel was in the air, or didn't hit the defense/obstacle first/last.
