Go to Post When in doubt, ask... don't assume (unless you don't mind wasting time/money). - Bill Gold [more]
Unread 24-01-2016, 23:22
Tiago_MARS Tiago_MARS is offline
Mechanical Lead
FRC #1523 (Mega Awesome Robotic Systems)
Team Role: Mechanical
Rookie Year: 2014
Tiago_MARS is an unknown quantity at this point
Gearbox dog gear problem (WCP DS WCD)
Our team is using WCP DS Gearbox with 3 CIMS and West Coast Drive. However, the dog appears to not move all the way against the dog gear so we're concerned it won't drive it properly when shifted into low gear. It moves up fine against the high gear though.
Has anybody encountered this problem before or know of a solution?
ID:	19871  Click image for larger version
ID:	19872  Click image for larger version
Unread 24-01-2016, 23:24
R.C.'s Avatar
Happy Birthday! R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Re: Gearbox dog gear problem (WCP DS WCD)
That spacing is incorrect. This is a common problem and is caused by incorrect spacing/tightening of the nut in the shifter coupler. Did you make sure the nut is in the exact spot shown in the manual?
You can verify this problem by shifting the coupler by hand and seeing if the gear on the opposite side moves from its original spot.
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
