Go to Post Now let's get back onto the original topic! :) - Calvin Hartley [more]
Unread 24-01-2016, 23:56
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
paper: 2016 Motor Specs
Thread created automatically to discuss a document in CD-Media.
2016 Motor Specs by Ether
Please report any errors in the specs or computed values.
Unread 25-01-2016, 01:21
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: paper: 2016 Motor Specs
Thanks for collecting and compiling this! It's always better to design from data than specs.
Unread 25-01-2016, 11:12
SmokeTest's Avatar
SmokeTest SmokeTest is offline
AKA: Mike Youmans
FRC #0116 (Epsilon Delta)
SmokeTest is an unknown quantity at this point
This "data" seems to be interpolated values based on straight-line approximation of the motor specs rather than actual measured values.
Unread 25-01-2016, 11:23
Ether's Avatar
Rookie Year: 1969
The data is the motor specs (both VEX test data and supplier's specs presumably from test data).
The Lookup Tables are interpolated values based on motor equations:
2016 Motor Specs from FRC Motor Manual and VEX Motor tests, with speed lookup tables
