Go to Post it is not as hard as it looks, but thats prolly cause we havent tried to build it yet... - robolemur1236 [more]
Unread 01-25-2016, 02:00 AM
PneumaticFlea PneumaticFlea is offline
Electroneer, Programmer, Webmaster
AKA: Lucas LeVieux
FRC #4014 (Top Hat Technicians)
Rookie Year: 2014
PneumaticFlea is an unknown quantity at this point
Where is the CANTalon class?
It's basically my first time programming an FRC robot, and it's our team's first time using the CAN bus in conjunction with the Talon SRX motor controllers. To be brief, where can I find the CANTalon class? I've found it referred to in many different places online, but it doesn't appear to be in the edu.wpi.first.wpilibj package. Even the JavaDoc doesn't have any entry between CANJaguar and Compressor.
I've uninstalled and reinstalled the 2016 version of everything multiple times. There must be something really simple that I'm overlooking. Thanks in advance for your help!
(if it helps, I'm using the command-based model with the Netbeans IDE on Windows 10.)
Unread 01-25-2016, 08:52 AM
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
Rookie Year: 2011
fovea1959 will become famous soon enough
Re: Where is the CANTalon class?
https://wpilib.screenstepslive.com/s...-documentation has the pointer to the javadocs.
javadocs are at http://first.wpi.edu/FRC/roborio/release/docs/java/.
Those show CANTalon in edu.wpi.first.wpilibj.
Are you sure Netbeans is pointing to the 2016 version of wpilibj?
Unread 01-25-2016, 08:55 AM
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Just to ask the stupid question, how did you go about installing an Eclipse plugin in Netbeans?
Unread 01-25-2016, 11:52 AM
AKA: Lucas LeVieux
Rookie Year: 2014
Thank goodness for your stupid questions! I used the instructions here to add the custom plugins. Turns out they haven't been updated since 2013! Doug, your intuition was exactly correct. I think that's probably the issue here.
Is there anyway I can update WPIlib and still use NetBeans? I'm particularly fond of/familiar with it.
Unread 01-25-2016, 12:59 PM
fovea1959's Avatar
AKA: Doug Wegscheid
Rookie Year: 2011
whoof.... there probably *is* a way, but I don't recall seeing one published.
problem one: getting the correct jars on your netbeans classpath; probably not a big deal.
problem two: deploying. have to figure out all the moving parts that Ant uses when doing a deploy under Eclipse. need to find the jar file)(s) that have the ant tasks in it that get used for doing a deploy, and the build.xml file(s), and any supporting files that get used during the build.
don't know if it's an hour's work or a week's....
Unread 01-25-2016, 02:51 PM
AKA: Lucas LeVieux
Rookie Year: 2014
Originally Posted by fovea1959 View Post
problem one: getting the correct jars on your netbeans classpath.
Where are the files? Is the source published somewhere?
Has the deploy software really changed that much? Could I potentially just use the old deploy stuff?
Unread 01-25-2016, 04:15 PM
fovea1959's Avatar
AKA: Doug Wegscheid
Rookie Year: 2011
the 2016 libraries would be in a wpilib folder off your user directory if you had Eclipse and it's plugins installed and working.
doubt you can use the deploy stuff; that's the majority of what changed with the new control system. You would need to really understand how it works in Eclipse and replicate that in Netbeans (or find someone that had already done it).
Unread 01-25-2016, 06:13 PM
AKA: Lucas LeVieux
Rookie Year: 2014
alright; that's too bad. it's probably not that big of a deal to switch to eclipse, though. (or perhaps, develop in netbeans and deploy in eclipse)
thanks a lot for your help! I really appreciate it.
