Go to Post You should qualify the same way you eliminate if you ask me. - sircedric4 [more]
Unread 25-01-2016, 10:51
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
Rookie Year: 2014
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Which newer Axis camera models work with Wpilib?
Our software team determined last year that IP cameras would be easier to use and have higher performance than USB cameras. I'm setting out to buy one, but all of the models listed in the WPILIB docs are discontinued. I can find the older models online, but it would be cheaper if I could get something stocked in Canada.
Does anyone know if newer AXIS camera's in the M10 line work with the 2016 control system? Specifically the M1004, M1014 or M1025? How about other IP cameras?
