Go to Post We found our bandsaw on Craigslist for $40. We keep looking for laser cutters and waterjets in that price range, but so far no luck. - chapman1 [more]
Unread 25-01-2016, 16:55
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
Team Role: Coach
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
Alternatives To OM5P-AN for Home Use
Is is possible to use a WiFi router other than the OM5P-AN for temporary development use only? With the OM5P-AN being in short supply at AM we'd like to setup our secondary control system with a linksys router. Anyone have any experience doing that?
Unread 25-01-2016, 17:07
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Rookie Year: 2007
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: Alternatives To OM5P-AN for Home Use
Any WiFi router/access point will do just fine. There is nothing particularly special about the OM5P-AN for simply controlling your robot.
All that you should need to do is configure the access point to serve up 10.te.am.xx addressess. In your case, it should serve IPs starting with 10.40.04.20.
The OM5P-AN does offer a great signal strength and some features that make it more reliable for use at competitions, but at home those features shouldn't be as critical. Also be aware that your own AP will allow you to break the 7Mb/s bandwidth limit, whereas an OM5P-AN with the FRC firmware will enforce that limit.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 25-01-2016, 18:12
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Be careful.
The OM5P-AN uses 12 volts, and prior years' D-Link uses 5 volts. Unfortunately, they have the same plug.
So, if you ever "accidentally" plug the Dlink into a 12 volt plug, you will likely fry the d-link.
Unread 02-02-2016, 09:42
snekiam snekiam is offline
FRC #3322 (Eagle Imperium)
Rookie Year: 2010
snekiam has a spectacular aura aboutsnekiam has a spectacular aura aboutsnekiam has a spectacular aura about
Originally Posted by rich2202 View Post
Be careful.
We have learned that you will not fry the dlink with 12 volts, but that does not make it advisable.
