Go to Post Does FIRST know about some rare inverted mushroom that I do not? - sanddrag [more]
Unread 26-01-2016, 08:14
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
New update to robot builder for c++ teams
We posted an update that fixes a number of RobotBuilder issues with the c++ templates. It is available as a stable release. To get it, change the URL that you use to get the plugins in eclipse so that the the word "release" is replaced by "stable" and then install the new plugins. You don't have to uninstall first, the stable version has a higher version number and eclipse will notice you are actually updating.
Please report back if you have any further issues
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 26-01-2016, 08:49
nollchr nollchr is offline
Rookie Year: 2014
nollchr is an unknown quantity at this point
Smile Re: New update to robot builder for c++ teams
Great news...just tested it...definitely fixed the nasty subsystem overwrite problem!
Thanks!
Unread 26-01-2016, 17:56
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
Team Role: Leadership
Rookie Year: 2014
MikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to all
The issue has not been fixed for us. Code is still being erased to an empty template when exporting. Header/command fines fine, just the subsystem/cpp files.
Edit: New systems with latest plugins work fine, mentors computer still does not. unsure of the issue on his still.
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 31-01-2016, 17:36
powster powster is offline
FRC #1148
Rookie Year: 2013
powster is an unknown quantity at this point
The new update has not fixed the overwrite for me either.
