Go to Post Blame it on the programmer. - colt527 [more]
Unread 16-08-2002, 02:33
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Help Gear Ratios !!!!!!! Help
I really got myself confused and I need some help.
For example....
Everthing on shafts is affixted to drive (e.g. pin, key, weld)
Say a motor has 5Nm torque.
There is a 10 tooth gear on the output shaft of this motor called "shaft A".
It drives a 40 tooth gear on another shaft called "shaft B"
Would the torque output by this last shaft be 20Nm?
Also, lets say there was also a 10 inch diameter wheel on "shaft B"
What torque would the wheel place on the ground??? for driving the robot.
I hope you know what I mean. If not ask a specific question so I can try to help you further understand my questions.
Thanks for the help.
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
Drill motor gearBox question Dennis Hughes Motors 4 11-10-2001 07:11
