Go to Post (Water on all this would be good too) - buildmaster5000 [more]
Unread 27-01-2016, 18:44
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
truncated mDNS name
Our robot is occasionally coming up as roboRIO-1296-FRC (as shown on radio status summary page) instead of roboRIO-1296-FRC.local, anyone else experienced this? We are using the new radio and a Windoze 10 development environment, C++ if that matters.
TIA
Fast, cheap or working - pick any two!
Unread 27-01-2016, 18:56
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: truncated mDNS name
I haven't looked, but I would expect that it would always come up like that. That's the actual host name. ".local" is a shortcut that indicates to use mDNS for the resolution.
Unread 28-01-2016, 00:20
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
That is what I thought but I could ping one and not the other. It finally worked itself out, frustrating to wait for though.
Unread 28-01-2016, 21:52
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
We are seeing the same issue on our side. We can ping 'roboRIO-3005-FRC' and 'roboRIO-3005-FRC.lan' but not 'roboRIO-3005-FRC.local' which means we cannot connect to the driver station. We can send code over LabVIEW, but only by changing the address.
We are using Windows 7 and LabVIEW with the new radio.
To fix, the only thing I have found that works is to reboot the system.
We tried updating the roboRIO firmware as well as disabling other network devices. None of this seemed to help.
Anyone have any ideas?
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 28-01-2016, 22:01
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
The OM5P-AN uses .lan, while the d-link uses .local.
We just assigned the rio to 10.te.am.2 and used that. mDNS has always been problematic.
Unread 28-01-2016, 22:18
wt200999's Avatar
Texas Instruments
AKA: Will Toth
This can't be it, when I reboot I can see the .local address just fine using the OM5P-AN.
What do you do for competition?
